Old 02-24-2005, 12:46 PM   #1
Drogster
Stroke it!
Drogster's Avatar
Swapping in a 454 in place of 307 - '68 C10 questions
I've got a '72 cast 454 block and heads that I'm going to be slowly building up.
And I'm sending out a check today to Tracey for the '68 Chevy C10 he's selling (thanks man!!), so it will soon be mine.
Anyhow...it originally came with the whopping 307 in it. Any tricks/secrets I need to know in regards to dropping in the 454 once it's done?
Thanks!
Drog
Nitrous is for those who don't know how to build.
Drogster is offline   Reply With Quote
Old 02-24-2005, 12:54 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You'll need big block engine mounts and stands, and factory big block pulleys and engine brackets. It's best to buy the whole setup as a mathced set off the same truck.
I swapped a truck over to 454 last year and it was quite costly to get all of the correct parts rounded up.
Old 02-24-2005, 02:44 PM   #3
Ptown72Chevy
i will be doing the same swap this summer. I still need to purchase all the parts.. what would awesome is if someone could post some pics of their engine comp. with a bigblock installed... good luck with your swap~JJ
Ptown72Chevy is offline   Reply With Quote
Old 02-24-2005, 03:50 PM   #4
RED67
Forever Grateful
RED67's Avatar
heres some mm's http://performanceonline.com/store/...6396&cat=&page=
this issue has been addressed before, you can do a search for a BB swap....good luck it's not as easy as it may look......when I have more time I'll let you know all the BS i went through........
R.I.P Dad 04-07-42 - 05-27-09
RED67 is offline   Reply With Quote
Old 02-24-2005, 07:08 PM   #5
Drogster
Stroke it!
Drogster's Avatar
I'd love to hear the stuff you had to go through...
Drog
Old 02-24-2005, 07:21 PM   #6
Striker169
Car O'Holic
Striker169's Avatar
I have a BB 454 in my 69. I can take some pics this weekend when I am working on it.
Striker169 is offline   Reply With Quote
Old 02-24-2005, 07:43 PM   #7
Drogster
Stroke it!
Drogster's Avatar
Sweet...thanks!
Drog
Old 02-24-2005, 08:10 PM   #8
Tx Firefighter
Here's a thread with lots of pictures of my old 70 model truck.
It started out as a 6 cylinder with no options. I converted it to a 454, auto trans, disc brakes, 5 lug, power steering, power brakes, all of that.
If you have questions just ask.
Lots of pictures: http://67-72chevytrucks.com/vboard/s....php3?t=127499
Old 02-24-2005, 08:51 PM   #9
bagged74
its just $$$$$
bagged74's Avatar
this one is stock, except the air cleaner
bagged74 is offline   Reply With Quote
Old 02-24-2005, 08:55 PM   #10
Bob Moore
Parts Needed
BB Motor
BB Motor mounts/frame stands
BB Alternator Brackets for SWP
BB Power Steering Brackets for SWP
BB Power Steering Pump for SWP
BB Power steering Reservoir for SWP
Optional/Would be nice
BB Fan Shroud
Heat Shield (for cab on pass side)
T400 with BB/T400 Shift Linkage Bracket(frame mounted)
High Hump floor(in cab)
3 or 4 Core Radiator with mounts
BB AC Brackets for SWP
It is not necessary to use the SWP and bracketry. I have a 454 in my 67 using LWP and brackets but they look more original and the wiring fits, etc using the correct SWP.
Let your checkbook be your guide.
Good luck - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 02-24-2005, 09:10 PM   #11
72402
Hey, I think I've seen that one somewhere before. Didn't know you had that picture.
72402 is offline   Reply With Quote
Old 02-24-2005, 09:15 PM   #12
XXL
Seņor Member
XXL's Avatar
They're so hard to find/expensive, I've pretty much given up on a BB swap and instead am contemplating a Motown-based SB from World Products... 427 or 454... there's no replacement for displacement... especially when you're hauling groceries and dropping your kid off at school
XXL is offline   Reply With Quote
Old 02-24-2005, 09:15 PM   #13
Tx Firefighter
you don't absolutely have to have a high hump cab with big block and turbo 400. A low hump cab will work too.
Old 02-24-2005, 09:35 PM   #14
bagged74
its just $$$$$
bagged74's Avatar
he will already have the 4 core radiator, the truck has one in it now.
Old 02-24-2005, 09:37 PM   #15
bagged74
its just $$$$$
bagged74's Avatar
I have pictures of everything. you never know when you might need them.
Old 02-24-2005, 09:50 PM   #16
Striker169
Car O'Holic
Striker169's Avatar
dam I have like no room in my engine bay for a 4 core radiator mines TINY and it has heat issues how the hell did you fit that massive radiator and fan in there?
Old 02-24-2005, 09:56 PM   #17
72402
[QUOTE]dam I have like no room in my engine bay for a 4 core radiator mines TINY and it has heat issues how the hell did you fit that massive radiator and fan in there?
If you're talking about the one in that picture, I didn't do it, GM did.
Old 02-25-2005, 01:12 AM   #18
Striker169
Car O'Holic
Striker169's Avatar
[QUOTE=72402]
yeah, could you take more pics of the like radiator and how they fit it in there and whatnot
Old 02-25-2005, 01:24 AM   #19
72402
Guys, it's just a standard 4-core radiator sitting in the stock location, same as a smallblock. I don't know what setup you have, but these trucks came with a short water pump and mine has a seven blade fan with a clutch. The fan shroud's different than small block too.
Old 02-25-2005, 01:35 AM   #20
bagged74
its just $$$$$
bagged74's Avatar
I have a smallblock and a 4-core so I have plenty of room. But like he said it s just a 4-core in the factory spot, nothing special.
Old 02-25-2005, 01:51 AM   #21
cduster
Originally Posted by bagged74
nothing special.
On the contrary, all of these old trucks are all special.
Dan
cduster is offline   Reply With Quote
Old 02-25-2005, 10:35 AM   #22
72402
Dan
Yeah, you're right about that. I guess that's the reason I've kept this one for 30 years.
Old 02-25-2005, 10:55 AM   #23
sakohntr
sakohntr's Avatar
swap
Its not as difficult as some make it out to be. I put a 454 in my K10 shortbox that originally had a smallblock in it. I used the same motor mounts but slid them forward 1.5 inches to make more room for the H.E.I. distributor.
I even used the longwater pump which was on it although that will be changed to original swp style soon. 4 core radiator, bb shroud, and fan fit perfect. You can use the remote style power steering with either the short or long water pump provided you have enough grooves on your crank pulley.
The only real mod i had to make was shortening the push rod between the clutch fork and z bar to compensate for moving the mounts forward. The headers even fit with the only issue being where they pass by the rear spring shackle. A little heat and a hammer gave me the depression to clear the bolt head. You wont regret the swap. May the torque be with you!
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 02-25-2005, 05:57 PM   #24
Drogster
Stroke it!
Drogster's Avatar
Sweet...thanks for the replies!
Drog
Old 02-26-2005, 04:30 AM   #25
Drogster
Stroke it!
Drogster's Avatar
These brackets?
Are these the brackets you all are talking about?
I don't know if this auction is for long or short waterpump...but either way I've found a bunch of these on ebay...
http://cgi.ebay.com/ebaymotors/ws/eB...category=34202
Drog
