Old 02-24-2005, 05:56 PM   #1
dave3156
Carburator Adjustment Help
About two weeks ago I bought a new Edelbrock #1406 carb. with automatic choke. I put it on and installed a new fuel line and new inline fuel filter. The carb that it replaced was also a #1406. It ran fine with the old carb, but could not get past Federal exhaust emissions testing. With the new carb it easily passed the test. I am disappointed with how the engine (350, mild cam, headers, performer RPM intake) runs with the new carb. I have read on other posts that it probably needs adjusted. The idle is too high and at speeds over 80 mph the engine bogs down and will not accelerate, in fact when you hit the gas pedal nothing happens over 80 mph, it continues to go at the same speed. It acts like it is fuel starved. Also low speed WOT performance is about the same as with the old carburator. I had hoped it would be better or I would at least notice a difference. I can hear more sound when the secondaries open but performance does not seem much better. I'm guessing it needs adjusted. I went to the Edelbrock website and alot of ajustment kits and parts are available? How do I know which kit I need? I am going to have a mechanic adjust the carburator, but want to get some opinions about what I need so I can have the parts he might need when I take it in. Can anybody help?
dave3156 is offline   Reply With Quote
Old 02-24-2005, 06:01 PM   #2
67chevemall
67chevemall's Avatar
Timing issue? I know retarding the distrubuter just right will pass the etest
here in Canada. Put the old carb back on and save that one for etests
Unless that was your last test.
Maybe fuel pressure. Is the new carb set up yet?mix and idle?
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-24-2005, 06:56 PM   #3
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
If the timing and Fuel filters are Ok , and you want to calibrate the carb , Kit # 1487 is for the 1406.
If you still have your old 1406 you might want to see if the Jet's or rods were changed in it ,and just swap them .
I've had several of these carbs and the are real easy to get running right had the 1406 on BB for a couple of years B4 the 1411 .
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 02-24-2005, 08:29 PM   #4
dave3156
Yeah, timing could be part of it. I didn't adjust anything on the carb yet. Just bolted it on and went. I'll check the old carb and look at the rods. I'm not sure I can tell the difference or know what to look at though.
Old 02-24-2005, 09:31 PM   #5
ezernut9mm
ezernut9mm's Avatar
st. louis has emissions testing???? i hope this doesn't spread across the state to us.
'06 silverado (daily driver)
'02 nissan sentra (wal-mart warrior)
ezernut9mm is offline   Reply With Quote
Old 02-24-2005, 09:59 PM   #6
Bill72BB
Bill72BB's Avatar
Dave , if you have young eye's the # are stamped on the Rods and Jets , my old eyes sometimes I have to use a magnifying glass.
Stock jets are .098 primary, Secondary's are .095
Rods are .075x.047 and the springs should be yellow.
BILL
Member DUF Club
Old 02-25-2005, 12:39 AM   #7
pritch
pritch's Avatar
I have that same carb on my boat ( ya-I know it's not a legal boat carb) and it has always ran too rich. I usually only take it out a couple times a year so it don't really bother me much, 'cause it still goes faster than I can ski, but what jets would it take to lean it out for 5000' of altitude?
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 02-26-2005, 04:31 PM   #8
Bill72BB
Bill72BB's Avatar
Here is the chart for the 1406 ,for leaning it out . I would start with # 12 on the Primary and 4% leaner on the Secondary's . That would just be a Jet change on both.
http://www.edelbrock.com/automotive/eps_1406.html
BILL
Member DUF Club
Old 02-26-2005, 06:25 PM   #9
RainFade
RainFade's Avatar
I had to take my 1406 2 steps richer on cruise and power (1455 rods) and to orange step up springs to get it running right.
Out of the box it acted starved when attempting to accelerate not even at WOT but just getting on it at speed (like say passing).
And that was after going through the fuel system totally.
Removed miles of ancient crappy rubber line where it was plumbed for saddle tanks, took screen off pickup, new pump. In short everything new from pickup to carb and it still ran super lean.
My engine is stock except for full length headers, a edelbrock 2101 performer mild rv cam and a procomp hei, not exactly a tricked out race motor by any means. Supposedly rebuilt around 30K miles ago according to P.O.
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes.
My lame K20 page
My lame Eaton disc brake page
RainFade is offline   Reply With Quote
