02-24-2005, 08:38 PM | #1 |
looking for a caddy 500 so cal
decided to go a differant route, so i am looking for a caddy 500ci engine. at a reasonable price. i found a couple at the junk yard but it has been rainy and wet. in the so cal area.
02-24-2005, 11:26 PM | #2 |
blood type; Retumbo
you may want to expand your search to include the 472. I have one from 68 & according to another website it has close to the same power. something like 525 lbft of torque @ 2800 RPM.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
02-25-2005, 07:01 AM | #3 | |
Caddy engines.
The gas formulas really bite compared to just 12 years ago. I tried running a 69 472 and had to cut the timing in half to run even high test fuel with out spark knocking.
1968 Chevy 4x4 307 4 speed |
02-25-2005, 09:54 AM | #4 |
its all about the +6 inches
hell, even the 425 is a beast and npretty easy to find.
I know where there is a 472, but it is in a car with no hood on it. |
02-25-2005, 02:35 PM | #5 |
My bother loved his 425 Caddy and it was great on gas mileage. Darn good choice!
02-25-2005, 04:39 PM | #6 |
i can get a 425 easily the problem is i got the itch for a 500. a 472 would be ok. i found a couple at the yard bu they were in front wheel drives. what does it take to get the engine out of there? any harder than a rear wheel drive??
02-25-2005, 04:54 PM | #7 |
Actually getting the engine from a front wheel drive one is better, becasue you will need the oil pan from one anyway if you are putting it in a truck. Im my area there are usually at least 15 of them in every junkyard I go in. I would wait until its dry for a while and they put new cars out though, unless you can find one in a car that still has the hood on it. lol
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
02-25-2005, 04:55 PM | #8 | |
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes. My lame K20 page My lame Eaton disc brake page |
02-25-2005, 05:13 PM | #9 |
it doens't matter to me if it's a fwd or not, but i have never removed a fwd engine so i'm not sure what's involved.
02-25-2005, 07:26 PM | #10 |
For most applications you want that rear sump Eldo pan! It's not the same as taking one from a rear drive. I saw your post on cowboy7 board. -I'm a bonafide expert on removing/installing in Eldo's/Toro's. Not usually one to brag, -if you don't have enough info yet, -email me and I'll get real specific. It's no big deal, -just different. smbker@cox.net
