Can I use the same clutch pivot bar 6 to 8cy
I am looking at keeping my 3speed manual and dropping in a small block. Can I use the same clutch pivot rod? Will it bolt from my 6cy to my 8 with no problems???
Nope - but if you're handy, anything can be modified. Start scouring wrecking yards. Does your V8 block have the drilled and tapped boss for the Z bar? If not, you need the offset adapter plate. Dubie took some nice pics of his conversion. Send him an IM. He'll respond when he gets time, his wife just got out of the hospital.
Silence is golden, duct tape is silver. - Scott |
blood type; Retumbo
I thought they were the same. the I6 has a funky shaped bracket to go from the block to the Z bar whereas the V8 has the Z bar- pivot mounted right to the block.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
Watch out for your cornhole !
![]() Join Date: Jun 2003
No, the z- bars are different. The rod between the pedal and the z-bar is different too.
If the bolt boss isn't threaded on the V8, I've drilled them and tapped threads into the block before. There is a flat spot where the hole should be. Just center punch it and drill the hole.
Still drivin' a Rat Rod
Hmmm mine has a bracket with the ball mounted on it that is right between the holes on my 350.In fact it bolts in both of them,one on each end
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
#6 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
lol I thought I used a piece I didn't need.It was in the back of the truck when I got it.
It was the only thing in the back of the truck ![]()
You're probably the only one that did it right!!
zbar?
Do I need one off a truck or any car V8? This isn't clearing things up(muddy).
Left Foot Functioning
TTT for ya, and I'm confused as well.
I understand that the V8 and I6 z-bar and rod are different, since I've seen reliable folks say so. But not knowing any better at the time, I used the stock setup when we changed I6 to smallblock (factory position). I had to move the frame bracket for the z-bar, mount the ball in the side of the block, and bend the rod slightly, but everything seems to work fine. Does anyone have pics of the different setups (I6 vs. V8 z-bar and pedal rod), or knowledge of why they are different? Is there some change in the mechanical advantage that would alter the travel or the force required? Thanks...SSOW ![]()
69 C10 (#1 son's ride) 72 C20 (Dad's farm truck) 82 K30 (Ex - brush pumper project) |
I just did this when I swapped my 350 over to an inline. It was a step in the right direction.
The pedal to z bar rod is straight on an inline engine and offset for the V8 engine. It's quite noticeable when you lay them next to each other, several inch offset.
Not an expert, but when I pulled the I-6 out of the '72 to swap in a V-8, I re-used the existing clutch Z-bar, bracktes, and pivot stud. Never had any problems with the clutch.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
#13 |
to 1969 K10
Where did you mount your motor? In the existing holes for the 6cy or did you move the stands?
