Old 02-24-2005, 09:11 PM   #1
magnethead
7000 #'s of american IRON
magnethead's Avatar
how long can you go?
The 454 started leaking oil today, making a bit of a burning oil smell, like oil is leaking out from under the valve covers onto the headers.
Why doesn't this surprise me? My dad says the whole time we've owned the truck, the engine hasn't been touched (except alternator, belt, & the such). I assume valve cover gaskets fall under that category.
keep in mind, thats 15 years in my life alone, we've had it bout 4 years before I was born. So a good 19 years on a set of valve cover gaskets....I dare ask what it would look like if we pulled the intake with the valve covers...replace em all at once.
magnethead is offline   Reply With Quote
Old 02-24-2005, 09:26 PM   #2
magnethead
magnethead's Avatar
I'm afraid to ask what we'd find if we pulled the truck out of commision for a bit and pulled the carb, intake, valve covers, and cylinder heads off. hmmm an almost 28 year old engine with >19 year old gaskets on everything...and it still runs with full load!
Old 02-24-2005, 11:39 PM   #3
cochran63
cochran63's Avatar
I would just replace the valve cover gaskets and see if that fixes the problem. If it doesnt then try something else.
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 02-24-2005, 11:44 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Yeah I'm thinking the same thing. If those seals and gaskets have held up this long, do not touch them. I afraid you might start a chain effect that wouldn't be good....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-25-2005, 12:03 PM   #5
magnethead
magnethead's Avatar
like say, more MPG maybe and less burned oil (although it don't really burn that much for it's age...)
So just replace the valve cover gaskets and see if that fixes it?
Old 02-27-2005, 12:23 AM   #6
jimfulco
Does it actually have gaskets or is there just a wispy bead of silicone? If there's a cork gasket, try gently turning the bolts tighter. Sometimes they'll need a quarter-turn or so, & that may stop the leak. If it's silicone, put some real gaskets on it.
jimfulco is offline   Reply With Quote
Old 02-28-2005, 06:14 PM   #7
magnethead
magnethead's Avatar
here's a couple pics with the air cleaner off...
not sure what it has...far as I know, the motor is 98% stock.
Old 02-28-2005, 06:19 PM   #8
magnethead
magnethead's Avatar
Few More...
Old 02-28-2005, 06:24 PM   #9
magnethead
magnethead's Avatar
and last 2...
Old 02-28-2005, 06:29 PM   #10
magnethead
magnethead's Avatar
You can see the "battery holddown" cord at the bottom of pic 6, the hydroboost system on the master cylinder, the 3 pics of the carbs, and the valve covers/headers. Also, on the choke butterfly, it had the number 3602 stamped on it with like a pair of 6's over a pair of 9' or something...couldn't tell.
