Old 05-31-2002, 07:05 PM   #1
kevins67gmc
kevins67gmc's Avatar
disc brake ?
how much difference in height between drum and disk brake front ends what im asking is with stock disk brakes front will it sit lower than the original drum brakes . thanks Kevin
kevins67gmc
Poulsbo,WA
kevins67gmc is offline   Reply With Quote
Old 05-31-2002, 10:09 PM   #2
Mike C
Mike C's Avatar
I didn't measure mine, but after the swap it looked really raked. I even added 1 1/2" drop shackles in the rear to get closer to the stock look. Still about 1-1 1/2" higher in the rear. Mine was a 3/4 ton swap. I pulled the parts off of a donor Longhorn which was a 70 someone had obviously done a conversion on so I have no idea what year the parts were from.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-31-2002, 10:53 PM   #3
kevins67gmc
thanks MikeC for answering my question Kevin
kevins67gmc
Poulsbo,WA
Old 05-31-2002, 11:41 PM   #4
MikeB
MikeB's Avatar
73-87 spindles will make a 67-70 C-10 truck sit prox 1" lower. Using 71-72 spindles should not change the height at all, but either way you will need a ton of other 73-87 or 71-72 parts, including the cross link, tie rod ends, and ball joints. Your best bet is aftermarket spindles from a company like Early Classic Enterprises. They will bolt right up to your stock 67 tie rod ends and ball joints, and use 71-72 rotors, calipers, and pads. They even manufacture 6 lug rotors.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
