Old 02-25-2005, 03:04 PM   #1
Chevyguy111786
Electric choke hook up ??
Where does the wire for the electic choke go? I thought i had it but i when i plugged it in, my temp gauge read all the way to hot...so i think i found out why my temp gauge doesn't work...but wheres the wire for my electric choke? i have an Edelbrock 1406 on a 305 in a 78.
Chevyguy111786 is offline   Reply With Quote
Old 02-25-2005, 04:12 PM   #2
60-66 Nut
Professional Beer Tester
Chevyguy, none of the 78's I've seen came with electric choke, only the manifold heat choke. You might not have a wire for it. All you need is a wire hooked into the fuse block on one of the terminals that are hot only when the key is on. Hope that helps.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 02-25-2005, 05:12 PM   #3
alpha_male0203
95 extended cab sportside
alpha_male0203's Avatar
Find a hot spot then a ground thats what i did i dont a have close pic or i would help but i have this one. There a red going in the back.
then i drilled a hole in the alt. cover for a good ground.
You cant see the black or the red but you can see in the right side there is a wire that is behind the 2 hoses its connect right there sorry if that dont help, and if it does thats good.
95 Chevy k 1500
00 Chevy Silverado 1500
07 cobalt Old ladies car]
alpha_male0203 is offline   Reply With Quote
Old 02-25-2005, 08:12 PM   #4
Chevyguy111786
oh so all it needs is 12 volts huh? sweet...didn't know if that was the case or not, thanks guys!
