02-25-2005, 05:34 PM | #1 |
Active Member
73-87 Garage Sale
I've got a some parts laying around I'd like to have out of my way. If you need something not listed just ask, I've parted out a few of these trucks and I might have it. Everything is OBO, if you want it we can probably work something out.
1. 14 bolt rear, full floater 3.73 gears pulled from a 79 3/4 ton. I drove the truck before it was pulled and there was nothing wrong with this. Complete from drum to drum and still has 8 lug steel wheels w/ 31X10.50 tires on theml. $150. 2. Pair of good doors. One has minor surface rust on inside lower edge, it's an original GM door with the tripod style mirror and full Silverado trim from a 79. The other is an aftermarket, complete with no mirror or trim holes. $150 for the pair. 3. 73-80 drivers side fender. Good condition, minor surface rust. Still mounted to inner fender, inner fender in useable shape but has a 5X5 rust hole towards the back. $50 4. 73-80 hood. Good condition, no rust. Two small dents in top, would be easy to fix. No rust. $50 5. 79 tilt column. It's a little loose, from a truck w/cruise. $100 6. 81-87 hood. Brand new in box. It's an aftermarket hood I picked up for cheap. It's got a kink on the top along the edge on one side, doesn't look like the hood itself is bent it's just low quality. $50 I've also got an 84 Silverado parts truck in the garage I'll be getting rid of soon. It's got power windows/locks and a good solid rear window. Would consider getting rid of complete truck for cheap but will likely be parting it out within the next month. I want it out of my way. No engine/trans - most underhood stuff is gone. |
02-25-2005, 05:43 PM | #2 |
hey man, i see you've been here for a while, but only have 3 posts. welcome to the board! where in IN are you? i'm in Elkhart.
02-25-2005, 05:55 PM | #3 |
*Proud Member*
looking for a power lock/door relay... should be under the dash in the middle... silver box w/ 2 holes that mount it and it has two small plugs on it.
let me know! thank you! |
02-25-2005, 06:02 PM | #4 |
'87
Hey on that 84 chevy that you're gonna part out does it have the stock wheels (rallies) by any chance??
02-25-2005, 07:25 PM | #5 | |||
Active Member
I joined last year and kind of forgot about it. I lurk around over here alot, there is a lot of good info to be had. I've been an active member over at fullsizechevy.com for a while to but there doesn't seem to be as big of a 73-87 following. I've also noticed there seems to be more people from the midwest over here as well. They're both good places for info either way and I'll probably be around both for a while. I'm about 40 miles northwest of Indy and 30 minutes south of Lafayette in Crawfordsville. Thanks for the welcome. Quote:
02-25-2005, 07:30 PM | #6 |
It followed me home?
If the '84 has delay wipers I'll take the switch.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
02-25-2005, 07:40 PM | #7 |
What sort of shape is the dash pad? Any cracks or tears? Need one for my '91 Burb. Price and shipping to 67152 if pad is good?
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
02-25-2005, 08:15 PM | #8 |
Active Member
Sorry, no delay wipers and I don't have any good dash pads.
02-25-2005, 08:20 PM | #9 |
What shape are the vent windows and body on the 84 parts truck. Any more details on it?
02-25-2005, 08:40 PM | #10 |
Active Member
Vent windows are in good shape. Doors and bed are junk. Drivers side fender is good, passenger side fender has dent in front, no hood. Cab is fairly solid and would be easily saveable. Floor is solid, I don't think there's any through rust in rockers but I think it has a couple small holes in the cab corners so they would need to be replaced. It's an A/C cab. I don't have a title for it. It's in the garage right now so it would be kind of hard to get a pic of it, if I've got time I might be able to pull it out this weekend and get a shot of it if you're interested.
02-25-2005, 09:43 PM | #11 |
Anti-Rice
02-25-2005, 10:56 PM | #12 |
Active Member
Which hood?
02-26-2005, 02:23 AM | #13 |
Does it have the (4) door pull strap covers?
84 K-20 Burb 94 Ranger 4X4 |
02-27-2005, 12:53 AM | #14 |
Sent you a PM on the axle.
Chuck '85 Chevy Silverado 4X4 '91 Chevy 4X4 Suburban http://www.cardomain.com/memberpage/545941 |
02-27-2005, 01:28 AM | #15 | ||
Active Member
Sorry, the strap cover were already missing. Quote:
Back atcha. |
02-27-2005, 01:57 AM | #16 |
Available for Adoption
I would be interested in the entire power window and lock setup from the 84??? shoot me a price...
1983 C10 SWB 2001 Silverado SWB 1995 Corvette |
02-27-2005, 02:02 AM | #17 |
Active Member
What do you consider complete? Is the wiring harness for those stand alone or are you going to need the entire interior harness? Door panels? I honestly don't know what a setup like this goes for so I'll have to get back with you on a price.
02-27-2005, 02:10 AM | #18 |
I think the wiring is mostly stand alone, but I'd settle for whatever I can get. I can wire up the rest if need be, but as much as possible would be great... Just let me know when you get a price... you can email me at
allthrtl(at)cox.net
02-27-2005, 02:18 AM | #19 |
Active Member
I'll be outside working on the yard tomorrow since it's actually supposed to be nice. I'll try to get out there and see what I can get off of it. I'm willing to let go of all of it, did you want the door panels as well?
02-27-2005, 02:23 AM | #20 |
Great....at this point I don't think I need the door panels, but you can give me a price, what color and what shape are they in???
02-27-2005, 02:25 AM | #21 |
Active Member
They're maroon, fair condition I'll see if I can snap some pics tomorrow.
