change to V8 and keep 3speed
![]() ![]() ![]() So do I mount everything in the 8cyl positon then get a different front driveshaft? ![]() Or will the Zbar from the V8 fit in I-6 zbar postion? Please help. This is getting confusing. David |
Its a Truck Thing......
I changed mine over from a 6 to a 8, in my opinion the best thing to do is change everything, I moved mine up to the 8 holes, got the right z bar, extended the driveshaft, get the proper steel mounts for the motor mounts, now on mine i had to get a different crossmember to move the trans up, the 6 trans crossmember and 1 I found in a yard for a 8 truck were different, I am very happy with the results, if you leave it in the 6 holes the engine will be close to the firewall, I dont like that, the only way anyone can tell my truck was a 6 truck is to look at the vin,,,,,,,If im right the z bar wont work at all, If I recall the z bar for a 6 is longer than the 8......
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
3sp
So, does anyone have a V8 zbar and the tranny mount for the 67-72 that has changed out to automatic? If they didn't just throw it away....
you can get the z bar from some of the vendors, check with atheys truck parts, he may have a used crossmember,,,,,
Watch out for your cornhole !
![]() Join Date: Jun 2003
I've always reused the 6 cylinder z-bar and screwed a pivot ball into the V8 engine.
with a 292 equipped truck, you will need to swap the rh frame stand , to mount in the I6 (250) spot. the 292 has staggered stands. for me, i use the V8 Zbar & top rod, with a screw in ball in the FOWARD hole in the block. the bottom rod will need to be adjusted, & the hloes redrilled in the frame (for the outter bracket), to get the Z bar pretty much perpendicular to the eng block. set up like this, you can run the rams horns, or opt for a 69090 set of hedmans......i think the Hooker comps will also fit, but my setup is a little different than the norm.....69L
http://community.webshots.com/user/hotrodhorn |
#7 | |
My truck, I used the I6 z-bar too though. Seems like I may have bent one of the arms with a prybar to make everything line up though. But, it was definitely the I6 z-bar
I-6 to V8
I got the motor stands off a 67 3/4 V8 frame. should I just put them in place of the 6cyl??
