Old 05-31-2002, 09:58 PM   #1
HeavyK20
HeavyK20's Avatar
Question Rockwell/NP205 T-Case Swap Q?
I am going to be replacing my Rockwell Tranfer Case with an NP205. Does anyone know if the Transmission to Transfer Case adaper sleeve is the same for both T-Cases? Also, will the drive shaft length need to be changed?
Eric
1969 K20, 465/205 package
HeavyK20 is offline   Reply With Quote
Old 06-01-2002, 12:02 AM   #2
Brian19692
I don't think the sleeve is the same but I can't remember for sure. The shafts need changed. I changed my 4-speed 4x4 over a few months ago. I had to move the t-case mount and cut a new hole in the floor for the shifter. I had the rear shaft shortened and used the front shaft from the 71 4x4 parts truck.
67 short 2wd. FOR SALE
69 long box w/72 grill
69 Camaro 327 4-speed
Des Moines, Iowa
Brian19692 is offline   Reply With Quote
