Old 02-25-2005, 08:57 PM   #1
4LUG39
How much fuel?
Ok Guys, when I take my sending unit out of my tank it works. I drop it back in and soon as it hits the gas It drops to E on the guage. Where is the short?
Will I blow my self up? It is A 69 C-10. Any ideas or advice.
Ain't no way in the world I'm going out that front door.
69 SWB Fleetside 327/5spd
76 blazer 383/700R4
95 2Dr Tahoe 5.7 4x4 LT
4LUG39 is offline   Reply With Quote
Old 02-25-2005, 09:02 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Curious,
Does it work when you move the float manually, if yes then check the float for a leak, thats a common problem, even new ones have a tendency to leak and read E on the guage...
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 02-25-2005, 09:07 PM   #3
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Sounds like you have a crack in the float. Usually they get cracked around the ridge where the wire wraps around 'em.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 02-25-2005, 09:10 PM   #4
jhow66
jhow66's Avatar
Try this:
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-25-2005, 09:14 PM   #5
4LUG39
Yes I can take it out and touch it to the tank and move the sending unit, it moves the guage. I set in a bucket of water at the shop and the float sat on top of the water the whole time, about 20 to 30 min. no leak. I dipped it in Por-15 tank sealer just to be safe. I took it apart and cleaned everything all the connections put it back in and the same thing.
76 blazer 383/700R4
Old 02-25-2005, 10:30 PM   #6
71swb4x4
71swb4x4's Avatar
You can run a temporary wire to the tank just to see if that fixes things. Just a few feet over the seat, plug it in, see if it works. If it does work than replace the old wire.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
