05-31-2002, 10:44 PM | #1 |
I am a Referee of life.
window felt runs
I know it been posted before but memory doesn't serve me.When replacing the window run felts,they rivet in.What type rivets did you use and what tips can you give me on getting it right?
I'm thinking just regular pop rivets would work but I haven't done these before so I would like to have a clearer picture before I start.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-01-2002, 12:02 AM | #2 |
there are no rivets on the felt in the back and top of the window. but on the front channel it is riveted(on the bar that is part of the vent window assembly. the rivets will come in a kit if you buy the window felt kit from someone. they are probably less than 1/8 diametr and 1/4 inch long? good luck, Ben
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
06-01-2002, 12:07 AM | #3 |
I got a kit from GMCPaul a few weeks ago and didn't get or need any rivets.
67 short 2wd. FOR SALE 69 long box w/72 grill 69 Camaro 327 4-speed Des Moines, Iowa |
