Old 05-31-2002, 10:55 PM   #1
flyin99
creator of kong
flyin99's Avatar
Question which power steering pump to use?
When changing from a long water pump, back to a short one, with a small block chevy, does the power steering pump change also? Where does it mount, if it is different? Thanks
flyin99 is offline   Reply With Quote
Old 05-31-2002, 11:25 PM   #2
Desert Rat
Desert Rat's Avatar
the pulley is different,and possibly shaft,be simplier to just use original style-
Desert Rat is offline   Reply With Quote
Old 06-01-2002, 11:37 PM   #3
Mike C
Mike C's Avatar
Also, GM switched from a woodruff key and nut pulley retention 74 and earlier to a 75 and later press fit pulley. At the same time, pulley alignment changed. (I have a 75 Corvette crank add-on pulley and PS pump pulley on my AGR pump. Summit sent wrong pump) All of the pulley alignments were different, so I could not use both of the 'vette crank pulleys, just the front one. You'd have to change water pump pulley and possible AC brackets. PITA.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-02-2002, 03:00 AM   #4
oleblue72
No, U Da Man!
oleblue72's Avatar
I used a ps pump off a 73 p/u.Just mounted it on my 72 brackets. Works great so far
(sold ole blue 1972)
1997 Dodge 1500 5.9L
1996 Saturn SL2 1.9L
2002 Mitsubishi Montero 3.0L
2005 Ford Escape 3.0L
1967 Olds Vista Cruiser 330-320HP
oleblue72 is offline   Reply With Quote
