Forever Grateful
how low can you go????
so how low can you go w/o having to use drop spindles for the front and c-notching the rear?????? anyone have any pics????
R.I.P Dad 04-07-42 - 05-27-09 |
someday it will be done!
I've been real curious about this too.Ricecop was kind enough to post pics of his new setup here .If I remember right he mentioned awhile back that he wasn't planning on using drop spindles.I don't know how much of a drop that works out to,but it's helping me visualize things a bit better.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
You can safetly drop the front up to 3 inches using dropped springs, and 4 inches in the back using dropped springs and no C-notch.
#4 | |
67 is sold
On my 72 SWB rear coil fame, I have a 6" rear drop with no c-notch.
I have heard if you go with the 3" front spring drop only you may have alignment issues. I have also heard you won't ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I've used 3 inch front springs and always aligned them with no problems.
In the rear, 6 inch drop is no problem without a c-notch. If you'll do a search under my name, you'll find pictures of my 70 with a 6 inch rear drop and no notch. I posted pictures of underneath the truck, showing the axle to frame clearance, so you can judge for yourself. I went with the guys advice at Early Classics. They assured me no notch was required, and they were right.
How much room is minimum between the frame and the axel for travel ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
I like at least 3 inches of travel (minimum) but some people are crazier than I.
where can you get 6 inch rear coils?
Any board vendor should have the coils for sale.
I buy all mine at Early Classic Enterprises.
Here's the picture of the axle to frame clearance on the 6 inch drop. I didn't measure it, but it was plenty.
I've put better than 800 or 900 pounds into the bed (fully dressed 454 big block and Turbo 400 trans) and it never bottomed out in any road conditions.
67 is sold
#13 |
Well I guess I got some more room to drop it. Nice.
