An American Soldier
![]() Join Date: Feb 2005
Power Steering Lines
I have a 69 SWB that the PO installed power steering on. He obviosly did not run the lines correctly, because he cut up the inner fender. Can someone tell me how they are supposed to be ran ...or even better, show me a pic? Thanks.
Dan dan.brue@us.army.mil |
Here is a pic of the lines attached to the frame. I think that is where you are having your problem since the PO cut the liner for clearance.
Jim |
Jim
Where did you get that clip to hold the power steering lines down? I need one of those.. ![]()
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
The clips are factory. The mid 70's trucks have them also. If you cannot locate one, let me know and I will dig thru my treasures to see if I have an extra one.
Jim |
Thanks again Jim. I got some cleaning to do around that area tonight so I will pm you and let you know.
An American Soldier
Okay, so mine does not quite look like that. I could use one of those clips also. Autozone told me they could order me lines for it. I just wonder if they are actually bent correctly or if they are just close so they can be used on various models.
Still drivin' a Rat Rod
The new lines should fit correctly,that looks like the PO just yanked some lines off something and made them fit.
Obviously a member of the "Whatever Works" club
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
It almost looks like the pressure line is mounted backwards. It just might lay down on the frame correctly if you undo the pump end and loosen the box end. The line should lay down like the earlier picture.
I had a problem with the lip of the inner fender grinding almost through the metal line. A little snip snip and fold the lip cured the problem. Good luck - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
Watch out for your cornhole !
![]() Join Date: Jun 2003
You're going to be disapointed when they order you the lines. The pressure line will be fine. The return line is a piece of hose and a couple of clamps. They expect you to already have the steel end with the fitting from your old line. You have to source the return line end from somewhere else.
As a member of the "whatever works club" I'm running a PS pump & lines from a 77 van. It works but it don't look right. What I do know from scouring the wreckers is there's a LOT of variations of lines out there, especially the steel parts. Good luck on your quest for the right parts.
I got a bench seat baby, you don't have to sit over there. |
