02-26-2005, 08:37 PM | #1 |
Electric Choke...
My electric choke(quadrajet 4bbl 305) doesn't seem to be turning off. It will just stay revved up, no matter how many times I hit the gas to try to turn it off.
If I shut the car off for just a second and start it again, it will idle just fine. As soon as I hit the gas to go again it will stick on again. Sometimes in a great while it will actually work like it is supposed to and stay off. What could cause this? Thanks, Scott.
1972 C10 1972 C20 |
02-26-2005, 09:02 PM | #2 |
Check your choke pull. If it is not working right it will cause the problem that you are having.
Jim |
02-26-2005, 09:12 PM | #3 |
Sorry, but what exactly is the "choke pull"? The little rod going into the round choke piece?
1972 C10 1972 C20 |
02-26-2005, 09:15 PM | #4 |
member #16
The choke pulloff is that vacuum pot on the right front of the carb. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
