Old 02-26-2005, 10:20 PM   #1
jermasaurus
jermasaurus's Avatar
Talking Just got my 3" Spindles and Flip Kit
I just got my spindles and flip kit (DJM). I would have had the flip kit yesterday, but the FedEx lady brought it to the wrong house.
jermasaurus is offline   Reply With Quote
Old 02-26-2005, 10:27 PM   #2
TIMSPEED
TIMSPEED's Avatar
So you're looking at this then...
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 02-26-2005, 10:37 PM   #3
jermasaurus
Yeah, if thats for the 1-1/4 rotors.
Old 02-26-2005, 10:39 PM   #4
jermasaurus
BTW does anyone have any pictures of what the control arm or brake banjo fittings looked like after their modifications?
Old 02-26-2005, 11:16 PM   #5
TIMSPEED
TIMSPEED's Avatar
See Them Here
Old 02-27-2005, 12:18 AM   #6
r0lf-
Hotwheels?
r0lf-'s Avatar
Before you get too far into it, go pick up some new U Bolts er... U... whatever they are called.
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 02-27-2005, 01:31 PM   #7
Slonaker
Insert Witty Text Here
Slonaker's Avatar
To "adjust" my brake lines to clear the spindle, I just put everything together finger tight as close as it could get to being right. Then I used a small prybar to pry the brake line away from the spindle. I just did this a little, tightened everything up, then did it again. I just did this several times until it all fit.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 02-28-2005, 01:51 AM   #8
jermasaurus
Well, I got the spindles done today. I ended up having to bend the brake line on the passenger side too. I also had to grind each spindle a little just above the caliper for the wheels to spin freely.
As for the flip kit... It didn't go so smooth. The u-bolt nuts were really a pain. I had to put a torch them and use a three foot cheater just to get them off. I broke one, but got four rew ones. So I got those off and went to take the leaf springs off, but the bolts through the bushings wouldn't even come of with the air chisel. I didnt want to torch them because I had no way to press the bushings in or out (plus being a sunday, I dont think anywhere was open to do it), and I only had a propane torch. So I think I am gonna go pay a place to put new bushings in, and then ill just take it home with the new bolts and bushings in, and remove them with ease.
Old 02-28-2005, 10:23 AM   #9
74Pumpkin
Insert witty comment here
74Pumpkin's Avatar
Did you happen to take some pictures in progress? I'm going to be doing the same thing this spring and would like to see how your went.
So many trucks, So little time!
74Pumpkin is offline   Reply With Quote
Old 02-28-2005, 10:42 AM   #10
jermasaurus
Yes. I did take some pictures. I have one comapring the old and new spindels, I have before and after pictures of the truck (But only the front is done now), and I will take another of where I had to grind the spindel. I'm gonna put them up in a day or so- whenever I get the back done. I am really hoping to get it done today.
