02-27-2005, 01:30 AM | #1 |
Rear coil spring installation
Just picked up a set of 3" drop rear coils at a swap meet. I have an idea of how I want to takle to job. Just want to see if there are any ideas, tips, or tricks to do the swap? My main concern is safety. How do I get the truck in the air to drop the rear without the front end wanting to roll down the drive we me under it. I don't have access to a lift so this is going to be done with a jack and jack stands.
02-27-2005, 02:35 AM | #2 |
block the front wheels, raise rear of truck and support with jackstands on rear frame rails, use floor jack under diff to support while you loosen spring bolts, lower diff and replace springs installing the lower bolt and retainer first. Do not tighten up just yet, raise diff until top of spring is in place to install upper bolt and retainer. Rotate spring until ends of the spring are aligned in the retainer cups properly, tighten bolts. Install wheels, remove jackstands, tighten up all bolts to proper specs. Drive it for about 500 miles, re-torque spring bolts... Enjoy!
78 C10 LWB Super Cheyenne |
