Old 04-08-2002, 02:25 PM   #1
Cal69Chevy
Cal69Chevy's Avatar
Post Gas spills out cap...
I swear I'm either losing my mind or the delusion that I had one at one point...I thought I asked this but can't find it now...so forgive me for asking it again if that's the case.
I have gas that spills out the gas tank that's behind the seat when its full and the truck is toss back and forth. it has a locking gas cap. I've tried another standard locking cap and it still leaks. it's definitely leaking where the gas cap seats. does anyone else have this problem and have you found a solution?
yeah i'd like to move the tank but that's not going to happen so i need to have a cap that can keep the fuel in...and i'd like it to lock.
as always, thanks in advance,
Ken
'69 Chevy, 4X4-SB 350 TBI-TH350 Trans-205 Transfer Case-Dana 44 Front-14 Bolt Rear-Front Disc Brakes-Factory A/C-P/S
Ken's '69 Page
Cal69Chevy is offline   Reply With Quote
Old 04-08-2002, 02:36 PM   #2
racedvl
racedvl's Avatar
Post
I would try taking a straight edge and see if your filler neck has a dent or an area lower than the rest. And if it does, see if you can straighten it out.
http://hometown.aol.com/racedvl/racedvl69index.html
Woodstock,IL.northwest of Chicago
It's not what you buy, it's what you build!!
I did not climb to the top of the food chain, to become a vegetarian.
For some pics of my truck.
racedvl is offline   Reply With Quote
Old 04-08-2002, 04:28 PM   #3
68 Suburban
68 Suburban's Avatar
Post
Don't put so much fuel in
Check out other members trucks
1968 50th Anniversary C-10 Suburban (Tows all these cars all over the place)
1968 50th Anniversary C-10 Pickup
1968 50th Anniversary C-20 Pickup CST
1969 SS Camaro Conv't
2000 Chevy Malibu (Suppose to be daily driver, but the Burb is)
Phoenix, AZ.
Click Here for Parts and Venicles I have Available
THINGS I AM LOOKING FOR:
67-68 SUBURBAN TRIM. $$$$ Reward
for finding the 3rd door trim piece
and the small piece that goes on
the 1/4 panel right behind the
3rd door.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 04-08-2002, 04:33 PM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
Post
I've learned to not put as much in my tank either - sad seeing it sloshing out all over the place. Very soon I'm going to get the tank made that will sit on my flatbed near the headache rack. Then my problems will be solved.
1969 C20 4x4 with roughly 6" lift and 35's
residing near Rose Hill, Kansas
Yukon Jack's Web Pages
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-08-2002, 07:36 PM   #5
MIKE'67
Post
I have the same problem. Tried several new caps. I just try to stop it at about 3/4 tank. Wish someone had an answer.
1967 Chevy white SWB, 327, 350 trans., 95 Silverado power buckets, frenched third brake light, frenched antenna, digital gauges, power windows, tilt wheel, Vintage Air, Painless wiring, Cragar SS wheels. Located in Albertville, Alabama
1977 Short Stepside, black, 350/350. Located in Albertville, Alabama.
MIKE'67 is offline   Reply With Quote
Old 04-08-2002, 08:26 PM   #6
71GMCstreet
Post
Same &#&&%#$5 problem, same types of band-aid fixes. This is what I did.....I put a thick bead of RTV along the rubber seal of the cap, let it set up, and since have had no problems.
71GMCstreet is offline   Reply With Quote
Old 04-08-2002, 08:56 PM   #7
Cal69Chevy
Cal69Chevy's Avatar
Post
i'm ready to learn something new...what's RTV?
Ken's '69 Page
Old 04-08-2002, 09:04 PM   #8
70shortnphat
"See the U.S.A....."
70shortnphat's Avatar
Post
roon teperature vulcanization
1970 short bed fleetside
1949 all origional chevy 3600
1974 camaro
Richmond , Texas(just S.W.of Houston)
70shortnphat is offline   Reply With Quote
Old 04-08-2002, 10:59 PM   #9
dion
72 Cheyenne
dion's Avatar
Post
I had the same problem, when my tank was full and I parked in my driveway butt first it would leak but if I parked face first it wouldn't, my diveway sloped down. Easy enough, face first, problem solved LOL.
72 Cheyenne C20
Built 350/T350
AC/PS/PB/AT
San Diego, CA
Pics of My Truck
<A HREF="http://photos.yahoo.com/bc/aikidojiujitsu/lst?.dir=/Chevy+Cheyenne+C20&.src=
ph&.last=1" TARGET=_blank>http://photos.yahoo.com/bc/aikidojiujitsu/lst?.dir=/Chevy+Cheyenne+C20&.src=
ph&.last=1</A>
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 04-08-2002, 11:12 PM   #10
chevy71super
Post
My 71 has vent tubing that used to go to a canister but the canister is missing. Someone plugged the tube so there was no where for the pressure to vent. The result was gas fumes coming out of the cap. I unplugged the vent tube and bought the right cap for a 71 and no more problems.
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
Old 04-09-2002, 12:32 AM   #11
imdarren
imdarren's Avatar
Post
I'm not saying that this is evryones problem, However, I went through this problem after installing a new gas tank. Went into NAPA auto parts and told them what year. They gave me a cap. We went out to check the fit on the truck, and it was loose. We tried the second PT# they recomended, and it was loose. We finally just started trying on caps until we found the correct one. It ended up being a PT# that there computer didn't even recomend. Bottom line... Try a new Non locking cap. Sorry I didn't keep the pt#. Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 04-09-2002, 05:56 AM   #12
GMCPaul
Talking
Use non-locking stant gas caps and in some cases over the years of putting on and taking off the gas cap the inner ring wears down, in this case stop at your local parts store walk in with gas cap hand it to the guy behind the counter and tell him you want either a rubber or fiber gasket ring that fits the outer ring surrounding the center section on your gas cap bottom side outer sealing edge, now take and slide it under the tabs on bottom of cap and reinstall. This .15 gasket thats 1/32"-1/16" thick gasket will be enough to keep your gas in the tank when full and cornering to the right at high speeds where it belongs. DO NOT USE RTV gasket material over time it will crumble and small pieces will fall into tank eventually getting into fuel line and carb causing other fuel problems.
GMCPaul
Online Catalog for-GMCPauls Truck Parts.com
67 LWB GMC SuperCustom Fleetside
67 LWB GMC Stepside
67 SWB GMC Stepside
67 SWB GMC Fleetside
67 SWB Chevy CST Fleetside
67 LWB Chevy CST Fleet
67 SWB Chevy Stepside
67 LWB Chevy Stepside
68 2wd Chevy 1/2 t. Panel
68 Chevy Panel 1/2Ton 4X4
68 LWB Chevy Fleet 4X4
69 SWB Chevy Stepside
71 GMC Suburban 402/400
72 LWB Chevy Camper Special
Nope not a typo 2-72 Camper Specials
and no they are NOT FOR SALE MINE MINE MINE and we accept ALL 67 Refugees Looking For More Never Enough!!!
GMCPaul is offline   Reply With Quote
Old 04-09-2002, 08:14 AM   #13
71GMCstreet
Post
I've had mine siliconed (RTV'd) now for 3+ years, no crumbling, decay or anything. I've run hundreds of gallons through it, no problems....but I will pick up a ring.
Old 04-09-2002, 11:13 AM   #14
Cal69Chevy
Cal69Chevy's Avatar
Post
thanks for all the great ideas...sounds like i might end up with a not locking cap...which isn't so bad...i'm sure i've spilt more gas than will ever be stolen!
Ken's '69 Page
Old 04-09-2002, 11:30 AM   #15
Duffy
Post
I too have played the locking gas cap game. The bottom line is they don't make one that locks (unless imdarren can tell us what number he is using) AND seals. I am using the Stant non-locking cap on my current truck and the last three or four I had before it - no leaks.
I worry about gas theft and someone dropping crap into the tank, but have never had a problem, at least not that I have noticed
How about it imdarren, can you look at your gas cap and see if it has a stant part number?
Thanks...Duffy
Duffy
'72 GMC Sierra Grande Custom Camper
Duffy is offline   Reply With Quote
Old 04-09-2002, 01:33 PM   #16
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Post
Well, there's an exeption to every rule! LOL
I bought a locking gas cap for my '69 and it seals good. I don't know what the name was. The only time it will leak is if I fill it to the top and park it in the sun. The gas expands and is forced out. Nothing is going to stop that but I can fill it to the top (and always do) and do doughnuts if I want (never do) and not lose a drop!
I also never get any fumes like alot here have mentioned. I must be lucky in the fuel department anyway.
63 Impala*66 Chevelle SS*69 Chevelle*69 C10 Stepside*71 Cheyenne 20*72 Chevelle
Parts for sale:
http://www.angelfire.com/trek/mr409/items4sale.html
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 04-09-2002, 07:08 PM   #17
Cal69Chevy
Cal69Chevy's Avatar
Post
great a new fear i haven't thought of...someone contaminating my fuel...now I really want a new locking gas cap...what cap are you using bob?
Ken's '69 Page
Old 04-09-2002, 07:49 PM   #18
imdarren
imdarren's Avatar
Post
The caps I'm refering to are NOT locking caps. I don't have a locking cap, nor would I recomend one. Like someone mentioned, you will probably "slosh out" more than could ever be stolen with most locking caps. Darren
Washington State
Old 04-10-2002, 07:47 AM   #19
bobs409
bobs409's Avatar
Arrow
Whew! I just went through the large envelope with all my reciepts! You guys better appreciate this. LOL
As far as I can tell, it is a Gates brand. Looks that way by the vendor code. The part number is: Vendor code-GA #31691 and was $11.12 I bought it at a Big A store here in Pottsville back in '99.
That's all I can tell ya. It's been on there all this time and like I said, I fill mine to the top all the time with no leaks or fumes.
Hope this helps.
Parts for sale:
Bob
Old 04-10-2002, 08:08 AM   #20
Maximum Overdrive
December 21, 2012
Red face
I have had locking stant caps on 3 of my trucks and never have had then leak. The only time I ever had a cap leak was when I had the old stock cap on the tank. I have heard many stories of people having their caps leak but I must have gotten lucky on this so far.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
