06-01-2002, 12:33 PM | #1 |
Question for SCOTI
You said your runing 20x10 rears with 295's. My question is how much you have to widen the tubs on your truck? You said yours is a fleetside truck right?
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
06-01-2002, 03:02 PM | #2 |
They are 20" wide from the inside bed wall to the edge of tub, 21" including the mounting flange where they bolt to bed floor, & yes it is a wide bed w/steel floor on the 67. They are overkill for 10" wide wheels but I use to have 15x14 steelies w/31x18.5 Mickey T's tucked up in there & since the truck sits so low, plans call for running the exhaust along the outside the frame rail & dump @ an angle right behind the rear tires. To fit them on the 68 I would just need to widen the factory tubs about 2" since the 4" backspace wheels currently on the truck don't rub the stock size tubs now. Since I only mounted them on the 68 for the '01 power tour, I just yanked the wheeltubs out for the week.
06-02-2002, 01:26 PM | #3 |
Registered Cruiser
Nice truck Low.
I intend to live forever. So far, so good. |
