02-27-2005, 09:45 AM | #1 |
1970 K10, 350, 4spd!
L/F Pic of a stock 4x4 with 33x12.50/10.50x15
Would also like to know what rim size you are using and its backspace if possible. I was looking through tirerack and they claim a 10.50 tire will not fit on a 10" rim, is that true? Anyone care to explain? Would like to see this tire without a lift on the truck.
02-27-2005, 09:51 AM | #2 |
Too many is never enough!
I've had plenty of 33/12.50-15s mounted on stock 8" ralleys no problem. Also have had 32/11.50-15s mounted on stock 7" wheels. Sorry, no pic right now but I don't know what they're talking about!
edit: Forgot to mention, I mounted 33/12.50-15s on stock 8" ralleys at stock height on my old '72 Blazer. Definitely filled up the wheels wells. They fit but rubbed a little making sharp turns. Only had them on a short while before I installed a 4" lift.
Jason 1968 K10 SWB Fleetside 1971 K2500 GMC LWB 1968 K20 (later frame, donor body) 1972 C20 LWB parts truck 1993 K2500 Suburban, tow rig, 454, 4L80E NEW!! 18' Siem's car hauler 2004 Honda Odyssey (family man!) Last edited by J.Lance; 02-27-2005 at 10:22 AM. |
02-27-2005, 09:56 AM | #3 |
Here's a pic of my '71 4x4 with stock spring height and 6 lug rallye wheels running 31x10.50x15's on it. Need to take another pic as since this one was taken I installed new springs on the rear but maybe it will give you an idea. New springs are on the front at time of pic.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 11-05-2006 at 06:27 PM. |
02-27-2005, 10:14 AM | #4 |
Better side view, new springs on front but not on rear yet in this pic.
02-27-2005, 02:25 PM | #5 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
33"x12.5" mounted on stock 8" ralley's(6 lug).
Stock suspension,no body lift on my 71 Blazer. They fit fine with NO noted rubbing even at full stuff.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
02-27-2005, 08:40 PM | #6 |
i got the same setup as bobby, 33,12.5 15` on an 8inch rim, no prolbems, and no rubbing.
jamie
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
02-28-2005, 05:13 PM | #7 |
I would not run a 10.5" tire on a 10" wide wheel, bead with let go EASY.
And if you run a 15x10 with no lift your going to rub, you need a 15x8 with about 3.75-4" BSing and you can clear them. I'm running 33x12.5" tires on 15x8 with 3.75" BSing with 1-ton 3 leafers in the front.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
02-28-2005, 06:52 PM | #8 | |
Workaholic
02-28-2005, 07:51 PM | #9 | |
Not to mention this kinda crap happens even running 25 psi
03-01-2005, 12:04 AM | #10 |
Just wanted to say that you have a really nice looking truck Destructo.
Mike |
03-01-2005, 03:04 AM | #11 | |
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
03-01-2005, 04:18 AM | #12 |
Here is a pic of my truck it is stock height with 33x12.50's on 15x10 rims no rubbing at all
