Old 02-27-2005, 01:41 PM   #1
sactoC10
71 DELUX
sactoC10's Avatar
POST HEI install quesions (few BUGS...)
OK, thanks again to this board and all the help with this upgrade. Now that it has been in for a couple of weeks, have a few problems/questions.
#1 Driver's side headlight is slow to come on when they're switched on, takes a minute or so...why is this happening? How do I correct it?
#2 Need to re-gap the plugs right? Re-gap them to what?
#3 Seem to have a slight loss of power (grunt/torque). Starts smooth, accelerates smooth, idles smooth...but seems to strain on the highway and (honestly) can't crack the tires loose like I could before!
Thanks again, in advance for any and all input.
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50
2003 FORD Escape
1998 Honda VTR1000
sactoC10 is offline   Reply With Quote
Old 02-27-2005, 02:20 PM   #2
RainFade
RainFade's Avatar
Not being an expert by ANY means but having just fought with putting a new HEI in my truck let me take a crack at this.
1: Probably not related whatsoever, pull the connector off the headlight clean them up inside with some tiny ignition files slather with silicone dilectrec and i'll bet your oxidized connection problem is gone. Alternatively check that your ground is good and clean it up.
2: .045" I am using R45 TSX (pre-gapped) in my 350 (71 pretty much stock)
3: Is your vacuum advance hooked to full manifold vacuum ?
What is your base timing ?
Do you have a timing light with adjustable advance ? if so what is your total mechanical timing and total timing with vacuum all in ? If not what is the source of your donor distributor and what #'s are on the vaccum advance canister IIRC they have the total advance stamped on them.
Any pinging ? flat spots ? backfiring ?
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes.
My lame K20 page
My lame Eaton disc brake page
RainFade is offline   Reply With Quote
Old 02-27-2005, 02:29 PM   #3
cdowns
cdowns's Avatar
when hooking up you did away with the factory(resistor) wiring right??>
Old 02-27-2005, 02:52 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That low power is a sure sign of timing issues. You should have at least as much power as before the swap.
Old 02-27-2005, 07:30 PM   #5
sactoC10
71 DELUX
sactoC10's Avatar
OK, thought the headlight thing might be related as I once saw a headlight re-wiring kit which is "suggested" after this swap/upgrade. I'll check the connections, tabs and such.
Donor HEI was nearly new with a new Blue Streak Performance cap, with adjustable vacuum advance. Maybe it is adjusted wrong? Not sure if it is at the full vacuum or not...maybe not.
Yes, factory resistor wire is no longer in use.
Haven't noticed any flat spots, pinging or backfiring, just some very slight "dieseling" after shut off ONE time, which was very brief. Don't have a timing light, not sure how to investigate that at this point. Hope it is a vacuum related thing, how do I investigate?
2003 FORD Escape
1998 Honda VTR1000
Old 02-28-2005, 02:59 AM   #6
dyingdeadman
dyingdeadman's Avatar
sounds like you got it a little too far advanced, you'll need to get a timing light and check it. you could probely get away with just playing with it a little, but the timing light is recomended.
72 GMC sierra 3/4 ton 402 bb
68 GMC 3/4 ton
2010 camaro rs: daily driver
dyingdeadman is offline   Reply With Quote
Old 03-04-2005, 08:12 PM   #7
sactoC10
71 DELUX
sactoC10's Avatar
OK, back after a few days... How do I "play with" the vacuum advance settings? I'd like to mess with it a bit without te timing light... what do I adjust?
Thanks.
2003 FORD Escape
1998 Honda VTR1000
Old 03-04-2005, 09:17 PM   #8
neonlarry
neonlarry's Avatar
Some reading for you:
http://www.corvetteforum.com/techtip...=115&TopicID=3
http://maliburacing.com/forum/viewto...f66070b98e4ee7
P.S. get a timing light even if its a cheap one.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 03-05-2005, 01:23 AM   #9
cduster
You should set the timing before you set the advance. Beg, borrow, or buy a timing light.
Dan
cduster is offline   Reply With Quote
Old 03-05-2005, 03:26 AM   #10
68c10owner
68c10owner's Avatar
you might try re-curving the dist. mr gasket sells a re-curve kit for hei`s. I used to use them in my mallory comp 9000. it comes with 3 sets of springs and new advance weights. i used the red springs because they were the lightest and let the mechanical advance come in sooner. you really need a timing light to do your timing accuratly.
Anthony
68c10owner is offline   Reply With Quote
Old 03-05-2005, 11:48 AM   #11
sactoC10
71 DELUX
sactoC10's Avatar
So, does anyone think I need a timing light? (J/K)
OK, will pick up a timing light soon, or at least borrow one.
NeonLarry, thanks again for all of the very helpful information!
2003 FORD Escape
1998 Honda VTR1000
