Old 02-27-2005, 04:57 PM   #1
Bowtiefreak
Bowtiefreak's Avatar
Disc brake pedal assembly questions
I got a couple questions:
Is there any difference in the pedal assembly on a manual pedal assembly in comparison to a truck that was already equipped with power brakes.
Do I need a different rod that goes into the brake booster. The one that is connected to the brake pedal??
Also, I got my assembly apart right now to clean a re-assemble and I pressed out the shaft that holds the actual pedal into the stamped housing. While getting this out I noticed that there are some sort of plastic bushings in there on each end. Are these available anywhere to replace? And what kinda of grease was used in there?
Help if you can,
Thanks alot everyone.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 02-27-2005, 05:04 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
What I have been told the rod is different due to pedal ratio, I would tell you to check with a specialty company like master power brakes, they can help with all your questions, I have manual brakes and when my truck gets back I can measure the rod if you like....
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 02-27-2005, 05:05 PM   #3
Sweet72
Sweet72's Avatar
Been a long time since I did my conversion from manual to power brakes, so I don't remember for sure but one of the pushrods was different. The plastic bushings are still available probably from a GM dealer and I've seen them in a catalog recently. If they're not totally trashed, reuse them. I think GM used white lithium grease.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 02-27-2005, 06:47 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If memory serves, not only is the rod differant, it is also placed in another hole on the pedal.
I am also 99% sure that the pedal assembly is the same power or non power.
Old 02-27-2005, 07:31 PM   #5
68c10owner
68c10owner's Avatar
I just got done tearing my pedal assembly apart on my 68 and there is only one hole in it for the rod. I`m installing a booster assemble from a 71 so I hope it works.
Anthony
68c10owner is offline   Reply With Quote
Old 02-28-2005, 11:20 PM   #6
6869704X4
Mine is a 4x4 and the rod is completely different. It doesent go from the pedal direct to the booster. There is a rod-end on both ends of it. Then you have the bracket, pivot then another rod goes into the booster.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
