Old 02-27-2005, 07:17 PM   #1
skokie
skokie's Avatar
Booster brackets
I saw a post on here a few months ago with pics on where they go on the mastercylinder, booster and firewall but I cant locate the post. If anyone has it bookmarked can you post it here?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 02-27-2005, 07:24 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That was probably a 71/72...they have brackets while the older ones don't.
Old 02-27-2005, 08:37 PM   #3
Harold Shepard
The round rod attachs to the back of the booster off of the lower left mounting bolt that holds booster to the bracket and attaches to the upper stud for the e- brake. The flat bracket attaches to the left stud on top of the M/C flange- order from outside in- bracket, prop valve backet, M/C flange. The other end of the flat mounts to spot above the flange that holds the steering column in place (one bolt at 12 o'clock -flange mounts here bolt is about 1.5 inches long- and one at approx.4 o'clock, bolt is about 1 inch long. Hope this helps.
Harold Shepard is offline   Reply With Quote
