Old 02-27-2005, 07:25 PM   #1
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
Question knuckle question
Bare with me here on another lift question. I have a 68 K10 and want to know what is involved in switching from a closed knuckle to an open knuckle is. Or if there is another alternative. The reason is I want to lift my truck 4inches and was told I need an open knuckle. Any help would be great.
jay_shy is offline   Reply With Quote
Old 02-27-2005, 08:09 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Unfortunately the only way to go from closed to open is to find a 1970 or newer axle and swap it in. 71 and newer will get you disc brakes. Shouldn't have any problems lifting a closed knuckle truck. The front springs are the same as the 69 and up. Your bigger problem would be the rear as lift springs are not available off the shelf. You could lift it in the rear w/ blocks or shackle flip.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-27-2005, 08:50 PM   #3
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
I will be using blocks in the rear but will I need a drop pitman or a draglink. I am confused here. I was under the impression I need an open knuckle for this reason.
Please help.
Jason
Old 03-26-2005, 10:29 PM   #4
67-72williso
Junk/Daily Driver Club
67-72williso's Avatar
Cool open or closed
You can use your original front (closed knuckle). All you need to do is correct your steering geometry.
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker.
There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened!
67-72williso is offline   Reply With Quote
Old 03-26-2005, 10:43 PM   #5
kwmech
That is if he gets a dropped pitman arm. You may want to consider the disc front end anyways as stated before.
Old 03-29-2005, 04:16 PM   #6
RainFade
RainFade's Avatar
You don't necessarily NEED a dropped arm for 4" of lift.
Ideally you want the drag link as horizontal as possible but I'll bet you'd be fine with 4"
However lift does often imply bigger meats and stopping that extra mass with drums may be a bit hairy. Heck the disc/drum on my 71 is funky enough under hard braking even unloaded that I'm accumulating parts for rear disc, 4 wheel drum and some big skins may be a quite exhilarating.
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes.
My lame K20 page
My lame Eaton disc brake page
RainFade is offline   Reply With Quote
Old 03-29-2005, 04:24 PM   #7
1969 GMC
1969 GMC's Avatar
yeah my truck has 4 whl drums and 32's, and while it was fine for a DD, and carrying smaller loads, it got "fun" when carrying a huge load and a ton of people, or if the brakes got wet
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 03-29-2005, 04:49 PM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
When I did my first lift of 4" the steering was much better once corrected. It wasn't a big problem, but great once corrected. My 69 also has the closed knuckle front end and an adustable drag link from Skyjacker or maybe it was Superlift got my steering corrected.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-29-2005, 09:37 PM   #9
69TowRig
Some '69s have open knuckles, my Blazer does. Of course you still won't have discs.
Here is an axle from a '72 for sale on Pirate4x4 for $300. I had to pass it up as I had already bought all my disc conversion parts:
http://www.pirate4x4.com/forum/showthread.php?t=339502
69TowRig is offline   Reply With Quote
Old 03-30-2005, 01:09 PM   #10
Rod
I think why you got told you needed a newer axle is because someone was thinking you were going with a bigger lift. At 4 inches I think you can use what you have. It is a closed knuckle in 68 so a disc brake swap isn't possible.
What I figure someone was trying to sterr you too was a cross over steering set up used in 8 inch lifts and such.
Good article here on flat top steering knuckles needed for that swap. http://www.pirate4x4.com/tech/billav...ngresearch.htm
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 04-10-2005, 08:50 AM   #11
Superron21
DONT TRY THIS AT HOME!
Superron21's Avatar
'68 GMC burb 6' lift
my steering is all stock w/ non adjustable drag link and it steers and stops fine with closed knuckles and all plus, no mud gets into my axle!
ron
Superron21 is offline   Reply With Quote
