Old 02-27-2005, 08:46 PM   #1
Smokin72on20s
Ebay Junky
Smokin72on20s's Avatar
Fuel injection for sale
I am selling my tuned port fuel injection, the price is $850. it is a complete setup from a 91 vette, all you need a distributor from a 90-91 vette with tpi or a iroc with tpi or a firebird with tpi, and a fuel pump.
Complete painless wiring harness, computer and accessories. This unit has 950-1000 cfm. Single wire installation. It is rated for 350-450 horsepower. Has all sensors and part numbers.
Polished top and fuel rails. Also chrome K and N air filter. Will fit 1965 to present small block Chevy V-8, older blocks will need to have the intake bolt holes enlarged.
the throttle body has two butterflies. the opening measures 7.5mm by 12mm.
it has 26lb injectors, the kit has adjustable chrome regulator, injectors are bosch, according to previous owner, the unit only has 20,000 miles on it, it could use a cleaning, but otherwise its in good shape.
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain..
1983 Chevy c10 swb 2wd - possible 350tbi supercharged...
Smokin72on20s is offline   Reply With Quote
Old 02-27-2005, 08:49 PM   #2
Smokin72on20s
Ebay Junky
2..
Old 02-27-2005, 08:53 PM   #3
Smokin72on20s
Ebay Junky
i forgot to mention, the unit comes with a new stainless polished bolt kit.
Old 02-27-2005, 09:43 PM   #4
smokinn
smokinn's Avatar
So this will fit my 82 350?
smokinn is offline   Reply With Quote
Old 02-27-2005, 09:50 PM   #5
71swb4x4
71swb4x4's Avatar
All you have to do is enlarge the center bolt holes on the intake. It is a common mondification on the later intakes.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-27-2005, 11:05 PM   #6
classicchev
classicchev's Avatar
computer out of the Vette also? What did you do for a engine, did you end up using the 383?
Later, Darren
classicchev is offline   Reply With Quote
Old 02-28-2005, 12:32 AM   #7
Smokin72on20s
Ebay Junky
yes it will work on your 82 350 with the bolt enlargement, i planned on putting on my 383, but ran out of funds before i could do so. I beileve the computer is also out of the vette.
Old 02-28-2005, 07:04 PM   #8
Smokin72on20s
Ebay Junky
ttt
Old 03-01-2005, 11:13 PM   #9
Smokin72on20s
Ebay Junky
how about $800?
Old 03-02-2005, 01:19 AM   #10
ZOOMY
parts
What's all needed to make this work ? I assume a painless wiring kit. What about sensors ? Are these units fussy about the cam used ?................Thanks..........Zoomy
ZOOMY is offline   Reply With Quote
Old 03-02-2005, 04:16 AM   #11
Smokin72on20s
Ebay Junky
everything you need is there, except a distributor and a fuel pump, i'm not sure what you mean by sensors? usaully a small block with 350+ hp has a pretty decent cam, and thats what this unit was set up for.
Old 03-02-2005, 12:28 PM   #12
smokekiki
Mike
smokekiki's Avatar
It is a corvette intake.You can tell by looking at the dist hole.The boss for the hold down runs straight with the back edge and there is a an egr valve hook up right in front of the boss,which is caped off in the photo.Vette intakes will work with pre 87 heads without mods.It is the camaro intakes that need the holes at a different angle.The only difference in a vette computer and a camaro computer is the vettes is water proff for use under the hood.Pretty good deal,considering the price the harness,larger injectors and throtle body.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 03-03-2005, 07:57 PM   #13
Smokin72on20s
Ebay Junky
ttt
