I have a radical idea!
Correct Cab Lights???
Does anydody know which and if a '67 C-30 could have had optional cab lights? My '69 C-30 has the round style (1st pic) but has raised bosses on the roof that they sit on. My '67 C-50 has the bullet style lights(2nd pic) and no bosses. I don't know if the ones on my C-50 are correct, but I can tell that they have been on there a LONG time. The amber lenses are almost white now,and the chrome is badly pitted. My '67 C-30 doesn't them at all, but I want to add whatever would have been correct for the truck. Thanks!
![]() OR ![]()
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Professional Grade
The top ones are correct for the earlier truck, cept they had flat tops (if I have any idea what I am talking about, lol)
I know for a fact that the bottom set are aftermarket, my 80 GMC has a set of those (they too have bad pitting in the chrome) and I just saw a 62 Mercury with a set of them as well.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
the top set are the ones my 72 1-ton has.This truck has been in the family from new and they are orignal
Yes, they are the same ones that my '69 has, I know they are original. I just don't if they were available in '67. I have never seen a '67 with the round ones. Is is possible that '67 didn't have them at all?? The '67's didn't have side markers because DOT didn't mandate that until '68.
oops i forgot,I have a 67 1-ton and it never had cab light on it from factory
67 trucks did not have the raised areas on the roof for the lights. Some may say 68's didn't as well, but there are a couple out there that do...just another one of GM's slick transitions to the next model year, I suppose
![]() The chrome lights are from the dealership, iirc.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Still drivin' a Rat Rod
I have a set on a 3/4 71 like the top ones,and a set of the bottom ones on a 75 4x4.The top ones are correct for the year.My 71 has raised bosses in the roof also.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
#8 | |
#9 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
![]() The dealer installed units are teardrop shaped like pic 2, with no hockey puck raised roof mount pads. 69/70 used a round lens on the roof mounts, 71/72 used the modified teardrop like in pic 1. Note: Series 40, 50, and 60, had the mount pads on their cab roofs in all years 67-72.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#10 | |
I had a 67 CST-10 years ago, and it had the option cab clearence & identification lights stated on the original glovebox sticker which I still have. It did not have the embossed roof panel, and had the bottom selection of lights on your pictures above. It was from a dealer in Crawfordsville, IN and was produced at the Flint, MI plant.
OT |
Tim,
Cool! Could you post pic of the glovebox sticker? I'd love to have that code. And you're saying they were the bullit style, right? Thanks!
#13 |
its all about the +6 inches
in 68, the roof clearance lights were required federally on all cab/chassis trucks with dual rear wheels.
However, GM got awqay with quite a bit....68 required side marker lights...federally...the weren't standard on our trucks untill 70 The mirror inside the cab...optional in 68.69...standard in 70n and up (and oddly enough, in 67 too) The were mandated in 69... ![]() So even though the roof lights were required in certian examples, that dsoesn't really mean too much. |
#14 |
I don't know about other states but here in Texas, cab markers are required on any truck wider than 80 inches. The chrome teardrop lights were factory installed on 67 and 68 trucks. The roof pads didn't start until '69, then they went to the hockey puck lenses. You could also get the teardrop lights dealer installed on all 10 and 20 series trucks that weren't ordered with the factory cab lights. I saw a K10 'Burb in Kerrville, Texas that had the chrome teardrop lights, and the original owner had the receipt from the dealer that installed 'em.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
#15 |
Yea, my 68 dually has the chrome teardrops which I was lead to believe were stock.
Pat ![]() ______________________ 1968 1 Ton Dually Flatbed 327/th400 1968 C30 Open Road 327/th400 1997 F350 CREWCAB 4X4 460 BIGBLOCK ![]() |
#16 |
You bet. I will try to remember to nab the sticker & a picture of the truck at the same time. I will have to dig a bit so if it takes me more than a day please dont be surprised. If you would like to respond to my e-mail address it is timothyl@vogelsheetmetal.com. This way I can send you a jpeg of both. I still havent taken the time to work out the picture posting efforts involved on the board.
OT |
#17 | |
#18 |
Ozark Tim has solved the mystery!! Some 67's did come from the factory with cab marker lights. Tim's '67 CST-10 came with them and the info is on the glovebox scan below. They are the bullit shaped chrome lights like in the 2nd pic. Sorry the pic is so big!!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 03-03-2005 at 11:19 AM. |
