Old 02-28-2005, 12:15 AM   #1
72longbed
72longbed's Avatar
Question 4x4 CROSSMEMBER QUESTION??
On a 71/72 K20, are AUTOMATIC and MANUAL transmission crossmembers the same part. Can they be interchanged with just different mounts??
Thanks for your knowledge,
72longbed
72longbed is offline   Reply With Quote
Old 02-28-2005, 02:30 AM   #2
4x4Poet
What different mounts? The mounts go to the adapter between whichever tranny it came with. AFAIK, oem '71/'72 adapters all used the two piece mounts. My '71 K10 w/SM465 and my '71 K20 w/TH350 use the same transmission xmember mounts. Both have NP205s, of course. BTW, Energy Suspension makes the two piece mounts in poly.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 02-28-2005, 10:32 AM   #3
72longbed
72longbed's Avatar
Question
4x4poet,
what is a AFAIK?? So the transmission mount is eliminated, and the crossmember bolts only to the transfer case adapter??
Let me know if this is correct.
Thanks,
72longbed
Old 02-28-2005, 01:12 PM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
thats right.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 02-28-2005, 02:34 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
As Far As I Know=AFAIK
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-11-2005, 01:43 AM   #6
68Shorty4x
I was going to ask about those poly mounts and thought I would jump in here. Any pro's or cons with these? Do I have to use there motor mounts to?
68Shorty4x is offline   Reply With Quote
Old 03-11-2005, 07:02 AM   #7
4x4Poet
I have Energy Suspension's trans mounts installed on my K10. p/n 3.1106G. I also have the xfer torque mount poly bushings. p/n 3.1107G. Motor mounts are separate, though my 71 K10's are not available thru Energy Suspension:
Cons: Cost. About $60 for the trans mount pair. About $20 for the torque bushings.
Pros: Impervious to oil, grease. Won't rot as rubber does. Retains shape. Made of soft poly to allow some flex and not transmit vibration. Comes with gold, cad-plated plates. Looks great if you crawl under the truck.
Old 03-14-2005, 02:13 AM   #8
Richard
I saw the poly engine mounts available at Brothers. They are listed as big block mounts. They are the same as the 4x4. I used the same crossmember on my last 72 that I converted from manual to auto. Had a donor truck.
Richard
