Old 02-28-2005, 12:17 AM   #1
crackajacka
Stylin
crackajacka's Avatar
gas to diesel conversion quest
ok i got laid off like a couple of days ago so i have lots of time to study this subject but i need some opinions. i have a 350 crate engine and im wanting to convert to a diesel. isnt the block basically the same as one used for a diesel? if thats true couldnt i just rob the top half of a diesel n the fuse box and swap it out to be a diesel? if thats true if anyone wanted to swap id be willing to. or if they wanted to swap a running diesel(100k or less) for a 350 gas engine(12k w/papers) id be willing for that.
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 02-28-2005, 12:27 AM   #2
u2slow
Web Wheeler
u2slow's Avatar
6.2L diesel heads don't fit the 350 block... its a completely different engine.
Best bet is to find a running diesel parts truck. There's lots of other equipment thats diesel-specific that you will need for a successful swap.
'66 C10 longstep - Clifford equiped
'84 C20 Suburban 6.2L - awaiting 4x4 conversion
'91 V3500 Crewcab - awaiting diesel swap
u2slow is offline   Reply With Quote
Old 02-28-2005, 12:29 AM   #3
crackajacka
Stylin
ok that solves that question but which one would be better on performance 6.2 or 6.5l?
Old 02-28-2005, 12:45 AM   #4
u2slow
Web Wheeler
u2slow's Avatar
The 6.5L has the added bonus of the turbo, but also the headache of increased electronics.
92-93 6.5TD's are handy as they are still fully mechanical.
The 6.5 non-turbo was used in some fullsize vans from 92-95. Also mechanical, but of course, no turbo.
6.2's are cheap by comparison, but lowest on the performance scale.
Old 02-28-2005, 12:52 AM   #5
crackajacka
Stylin
is there the possibility of a mechanical 6.5 with a turbo or twin turbos?
Old 02-28-2005, 12:55 AM   #6
Russell
Professional Grade
Russell's Avatar
There is if you do the conversion
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 02-28-2005, 01:13 AM   #7
grape
grape's Avatar
they are the same engine from 82-2000, bore increased 2mm in '92 to become the 6.5. you dont' need two turbos, just one correctly sized one.
grape is offline   Reply With Quote
Old 02-28-2005, 01:51 AM   #8
krazy_texan
krazy_texan's Avatar
best bet would be to find an old military blazer or truck or something along that line that has a diesel as a donor truck because they usually have really rough bodies and can be had for realitivly cheap
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 02-28-2005, 01:53 AM   #9
kevinr1970
If only you were closer........
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 02-28-2005, 02:34 PM   #10
Beefcake
6.2's are very easy to find. There super cheap for 2 reasons. People dont like the low amount of power, and when abused the cranks are known for grenading....
The reason why I pick up every 6.2 I can find is:
depending on the wear, you can upgrade bore/piston to a 6.5. Adding a 6.5 turbo is simple....
also, my 84 suburban gets 22- 28 mpg. -the 6.2 heads are restrictive, but give awesome mpg.
72 GMC Camper Special 2500.
currently has 350/350/14 bolt. 383 and 400 tranny is in the works.
Beefcake is offline   Reply With Quote
Old 02-28-2005, 05:00 PM   #11
JustOneTruck
JustOneTruck's Avatar
I`m new so this maybe just old stuff to you guys. Is this "Grenading" when you over load by towing or heavy loaded that the cranks let go.
I drive mine just to work and back 5 miles{10 total}. But the weekends it gets 30 to 40 miles on it. Im soon to be moving and will be using a inclosed car trailor to move our house hold stuff. I just have to take it easy right.
1984 6.2 automatic 3.43 gears 1/2 ton long bed it says class 5 hitch .But I know I`m not going to be towing 8000 lbs .
JustOneTruck is offline   Reply With Quote
Old 03-01-2005, 12:17 AM   #12
lofat
Rollin' Member
lofat's Avatar
this is interesting. i have been considering converting my truck to diesel for a while. finding a 350 is easy as it gets, new used rebuilt - but in my limited searches i have come up with not so much.
i would be interested in some links if you got em to rebuilds, or tips outside of finding a donor which i don't have the space to store (apartment living - ain't it grand) or buying new.
thx
:: 1977 C10 cheyenne ::
:: 1973 new yorker brougham :: for sale - $1,500
lofat productions
lofat is offline   Reply With Quote
Old 03-01-2005, 09:57 AM   #13
Beefcake
Grenading: Its my term for when the crank shatters into a billion pieces. Basicly the 6.2 and the 6.5 are prone to it. Reason is the 22:1 compression, and abuse. Abuse means doing neutral slams while under load, overloading, and turning up the IP for more perfomance without other upgrades. Then there is maintenance:
Maintenace on a diesel: #1 most important, make sure your harmonic balancer is in top shape. Id replace it every 100k miles just to be sure. Replace both filters every 3k miles, one is on the intake other is by the fuel tank. Do your regular oil changes... I've heard that putting 50/50 (2 stroke) mix in the gas tank every time you fill up will save your IP. 400k miles on a 6.2/ 6.5 is obtainable. So if your not doing everything right, you should be able to get atleast half that.
Doners can be found in most military vehicles, and 80' and up vehicles. I've bought 2 6.2s one in a suburban, other on ebay. The one on ebay had a broken crank- I bought it for the parts... got it for 100 bucks. Bought the suburban for 400. People dont like these engines cause they really dont have much power.... So just keep your eyes open and you'll find them.
Good luck! - let me know what you guys find.... I sure wish we could have a diesel page on this board.
