Old 06-01-2002, 04:46 PM   #1
Custom 68
Custom 68's Avatar
Is TPI really worth it?
Have you added TPI from a donor car? Is it a good thing? What should you expect to gain. Is it better to stick with carb untill you can afford an aftermarket one?
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 06-01-2002, 06:08 PM   #2
68 with 350 TPI
68 with 350 TPI's Avatar
I will let you know if it is in a few months when I get mine all in and running right.
Until then you can email me at Schulzautomotive@Hotmail.com
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 06-01-2002, 08:26 PM   #3
JJ
Lurking Member
Thumbs up
That all depends, how do you feel about easy cold starts? Good throttle response with improved performance? Better mileage? More torque at the bottom end? And a bit of envy when people look under the hood? Yeah, it's alot of work getting all the sensors and switches set up, but heck, so is everything else you do.
JJ
72 GMC 1500 350 4 Speed, stone stock baby!!!!!
72 GMC K-2500 350TPI 700R4
For those who fought for it, Freedom has a flavor the protected will never know.
JJ is offline   Reply With Quote
