Old 06-01-2002, 05:12 PM   #1
Andrew68c10
Rust Prevention inside Rockers
Is anybody doing anything to prevent rust inside the rocker panels? Mine has some surface rust that I can sand off and treat, but I'm concerned about the inside. My idea is to cut a couple of small holes in the back of it to clean it out and get some rust converter and coating in there. Any thoughts?
1968 Chevy C10 Longbed Fleetside
Andrew68c10 is offline   Reply With Quote
Old 06-01-2002, 05:22 PM   #2
shortbed70
shortbed70's Avatar
Sherman williams Industrial 2 part A B primer in black works really well. I prime military vehicles with tis and it vertually in penatrable in fact I used some on my complete undercarrage 1 year ago over rust and all and haven't seen any bleed through yet. Don't use it on exterior though because auto paint will not stick for long..
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 06-01-2002, 09:30 PM   #3
Stroker
See if you think this would work for you
http://www.eastwoodco.com/cgi-bin/sg...KW=TRP5&FNM=20
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 06-01-2002, 09:35 PM   #4
Andrew68c10
I have the epoxy primer and Rustmort, which should work well. What I'm worried about is cutting holes through the backside of that rocker. Would that cause other problems, such as body flex, or open me up to more corrosion?
The Eastwood stuff looks like it might be the same as ZeroRust, which I have also ordered.
