Old 02-28-2005, 12:32 PM   #1
muddpile
muddpile's Avatar
Stock Headliner Questions
I recently cleaned up my door panels and saved myself about 150 bucks by not buying new ones. I was thinking about putting the money I saved towards a stock headliner with chrome trim. What truck package originally came with a headliner? Mine has no evidence of there ever being one up there, but I kind of like the look of them and figure it would be worth doing. Also, how much is involved in installing one and is it worth it? Is the vinyl mounted to some sort of cardboard or is it a plastic? What about the chrome, is it metal or plastic? Thanks!
muddpile is offline   Reply With Quote
Old 02-28-2005, 12:45 PM   #2
70 longbed
I have a 70 CST with the headliner. Mounted to cardboard and the trim is metal.
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 02-28-2005, 12:50 PM   #3
JimKshortstep4x4
Smile
Headliners are nice in that they cut down on the noise inside the cab. The cab is punched in the roof on the trucks that came with the headliners so as to snap the trim in place. You can still glue the headliner in place and screw the trim to the cab with short screws.
Jim
Old 02-28-2005, 12:53 PM   #4
Mudder
Mudder's Avatar
The trim is plastic. The original liners where attached with clips in the plastic trim into little retangular slots in the roof. I took the clips off of my new trim and used very short screws. (maybe like 3/16 or so). Very short. Bought a used headliner from Manes in KC/ painted it then glued it along with the screws. No problems.
Mudder is offline   Reply With Quote
Old 02-28-2005, 12:56 PM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
Originally Posted by muddpile
...What truck package originally came with a headliner? ...
CST (69/70); Cheyenne/Cheyenne Super (71/72)
...Also, how much is involved in installing one and is it worth it? ...
Headliner trim has clips and screws to fasten it. The cab roof has elongated holes to accomodate these clips. Big PITA to retrofit a non-headline cab. Your best option is to forego the clips (break them off) and use the screws only. The headliner itself is glued to the roof to prevent sagging. The trim does little to hold the headliner in place, it's cosmetic.
... Is the vinyl mounted to some sort of cardboard or is it a plastic? What about the chrome, is it metal or plastic? Thanks!
Cardboard-like material as backing, at least OE is. The trim I've seen has always been chrome-painted plastic (OE or aftermarket). These have been 71/72 trucks, so maybe 69/70 used steel.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 02-28-2005, 02:00 PM   #6
70 longbed
Maybe I need to look at mine again, and also not respond until I am sure. I probably confused him as much as I am now.
Keith
Old 02-28-2005, 06:41 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the 69/70 was plastic also.
make sure you use short screws...the guy who used to own my old SWB drilled screws right up through the roof.
Not cool.
Old 02-28-2005, 07:44 PM   #8
Pilgrim
My headliner has no trim, looks better.
Bob
68 C20 Camper Special
Pilgrim is offline   Reply With Quote
Old 02-28-2005, 07:46 PM   #9
sdkid
My 70 had a headliner. The trim was plastic.
sdkid is offline   Reply With Quote
Old 02-28-2005, 09:07 PM   #10
incoma
incoma's Avatar
You guys are right on about the trim being a PITA. When I was tearing out my interior that plastic trim had to be ripped out. It broke into many many little pieces. I have to say that that trim, my park brake cable and 2 bolts were the only casualties in the tear down too. I'm considering removing the tangs on the trim when I reinstall. That way if I ever need to remove the headliner, it doesn't mean replacing the trim!!
incoma is offline   Reply With Quote
Old 02-28-2005, 09:43 PM   #11
gonebad2
Merciless Butcher
gonebad2's Avatar
My upholstery guy covered my stock headliner in leather, He sewed a nice pattern in it. It's quite a bit heavier than a stock vinyl headliner. I covered the back of the headliner with liquid nails and propped it up very tightly with boards to let it dry overnight. I did'nt use the plastic trim and the ceiling wasn't punched with slots for the trim. I personally think it looks better without the trim.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 03-01-2005, 01:32 AM   #12
muddpile
muddpile's Avatar
My truck is definitely not an original headliner truck. There are no slotted holes or any evidence of there ever being adhesive up there (except for an old bumper sticker that is stuck to the ceiling that reads "Hire the morally handicapped". Sounds like the headliner with no trim is the way to go. It's nice to know that works, as I'm not particularly fond of the trim myself either. Liquid nails and a couple pieces of wood to prop it up sounds like a good idea. Looks like this is another mod to add to the list. Thanks guys!
Old 03-01-2005, 09:13 AM   #13
Bowtiefreak
Bowtiefreak's Avatar
I did the same thing Gonebad did except I covered mine in matchng velour(sp) of my seats and door panels. Then to add a little more sound deadening, I used some of the B-Qiet sound deadening material in between the roof and the headliner. Should add some quietness to the cab. Looks great.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
