Keep On Truckin'
Rear leaf, lowering front hanger question
I've been looking for 2" lowering front hangers for a '72 rear leaf spring truck but have been unable to find them. Does anyone know if they are available and if so where they got them.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
You can get a 4" front hanger/ shackle for the 73 & later trucks.....but I dont think you can get em for the 67-72 leaf (red headed step child trucks). I did an axle flip on my longhorn, & 1/2ton pcs....the spring hangers were also moved on the frame to get the "stance" where I liked it. that is the only 1/2 ton longhorn I know of.....(not factory tho
http://community.webshots.com/user/hotrodhorn |
#3 | |
Keep On Truckin'
Did you have to notch the frame with the flip kit? I don't want to notch the frame but I'm afraid with a flip kit I'll have to in order to prevent the axle tubes from slamming into the frame on bumps.
Progress = 0%
On my GMC leaf spring chassis (before I switched to coil spring chassis) I raised the whole front spring mount up 1.5" or 2" on the frame. Then I lengthened the rear hangers by the same amount and took out a couple of the leaves. I remember I had to notch one of the bed supports for clearance.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
#5 | |
