Old 02-28-2005, 09:41 PM   #1
1974gmc
In Progress
1974gmc's Avatar
sway bar
picked up a sway bar from the wreckers today, but i couldn't ge tthe frame brackets off cause the rivits. how have you got them off?
i got the sway bar off a 3/4 ton but ended up only being the 1 1/16 bar, i was hoping for the 1 1/4 but im still happy. i got the bar, new bushings, brackets, and new hardware for $80 canadian
1993 Chevrolet K2500 454 4L80E
1974 GMC 1/2t 2wd Stepside 305 auto *sold*
1985 Ford Mustang GT 5.0 5spd
1974gmc is offline   Reply With Quote
Old 02-28-2005, 10:27 PM   #2
78chevstepside
78chevstepside's Avatar
I recently added a sway bar to my 78 and love the results. The brackets on those are rivoted on. I know of 5 ways to get them off 1. torch easiest 2. drill 3. grinder 4 . chisel hardest. 5. sawsall. I like the grinder or torch method the best. I went down to the chevy dealer and bought new ones 16 dollars each .
78chevstepside is offline   Reply With Quote
Old 03-01-2005, 12:09 AM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I bought mine at the dealer too. It wasn't worth spending an afternoon on my back laying in oil soaked dirt to save $20.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-01-2005, 12:45 AM   #4
1974gmc
In Progress
1974gmc's Avatar
i phoned gm today and they wanted $32 canadian each, not worth it for me
when torching them do u just heat them up and knock em out?
Old 03-01-2005, 05:42 PM   #5
67chevemall
67chevemall's Avatar
I just took one off a 78 and it was bolted on 4 bolts a side?
It's 4 sale $60.00w/brackets
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 03-01-2005, 06:12 PM   #6
Slonaker
Slonaker's Avatar
Look at all the trucks in the junkyard before you start removing rivets. Some might have been added with bolts, like mine, or might have been replaced with a bolt-in after an accident.
If you get lucky, you can melt the heads off and hammer the rest through with a punch. If not, they will be like the rivets on my upper ball joints that each took about 20 minutes of hammering to push them through after the heads were ground off.
Slonaker
Stock '01 Silverado
Old 03-01-2005, 06:41 PM   #7
Zilverado
Zilverado's Avatar
If you have access to a torch, I thought you might also have access to an air compressor. If you do...
On mine I used an air hammer (chisel), with a chisel tip to remove the head of the rivet and then used a punch tip on the air hammer to drive the rivet through. Worked pretty good.
Of course, if you are doing this at the bone-yard, you may not be able to hook up a compressor.
Just a thought.
Zilverado is offline   Reply With Quote
Old 03-01-2005, 10:13 PM   #8
1974gmc
In Progress
1974gmc's Avatar
ya i guess i should have looked around at the other trucks to see if any were bolted in. thanks for the info!
Old 03-02-2005, 12:37 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
If your truck is lowered consider either the low profile ones the ECE sells, or don't run them at all....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-02-2005, 02:07 AM   #10
1974gmc
In Progress
1974gmc's Avatar
would it be possible to bolt the sway bar brackets directly to the frame without the frame bracket?
Old 03-02-2005, 09:35 AM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes it is possible. If your truck is stock height it wouldn't be advisable due to the angle, but if it's lowered it will work just fine. I bought a set of the low profile stands from ECE for 20.00...
Old 03-02-2005, 11:22 AM   #12
SCOTI
SCOTI's Avatar
Like N2TRUX said, it will work fine if the truck is lowered. My 74 & 68 both have sway bars w/o the factory brackets. The 68 has been on the road since 2000 & the 74 since summer 03, both w/o any sway bar related problems.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-02-2005, 11:50 AM   #13
Slonaker
Slonaker's Avatar
I don't think his truck is lowered. Even if it is, that might not be a factor. It depends on how it was lowered. My truck is lowered using just drop spindles. That has no effect on the sway bar because the lower control arm does not change in relation to the frame. It only changes the angle if you use drop springs.
Slonaker
Stock '01 Silverado
Old 03-02-2005, 04:01 PM   #14
1974gmc
In Progress
1974gmc's Avatar
no its nots lowered yet... one day it will be
Old 03-02-2005, 08:54 PM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Slonaker
..... My truck is lowered using just drop spindles. That has no effect on the sway bar because the lower control arm does not change in relation to the frame.
Good point. I was assuming if it were lowered that it would have dropped springs.
ok since you aren't lowered then you will need the factory stands....
Old 03-02-2005, 09:15 PM   #16
1974gmc
In Progress
1974gmc's Avatar
went back to the wrecker and found a 70-72 pickup with them bolted on and even better he gave em to me for free!
Old 03-02-2005, 10:46 PM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
....even better he gave em to me for free!
That's sums up my favorite philisohpical quote. Cheap is good, but free is better....
Old 03-03-2005, 01:14 PM   #18
1974gmc
In Progress
1974gmc's Avatar
i finished putting it in today and what a difference, a lot less body roll now!
Old 03-04-2005, 12:28 PM   #19
1974gmc
In Progress
1974gmc's Avatar
here it is finished:
click on thumbnails for bigger pics
Old 03-06-2005, 10:50 PM   #20
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Looks good. Did you paint the bar too?
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 03-07-2005, 01:30 AM   #21
1974gmc
In Progress
1974gmc's Avatar
ya just some plain black paint, stands out from the rest of the dirt under there.
Old 03-07-2005, 02:47 AM   #22
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
I am hopefuly in the market for a sway bar. what years will work on my truck and what size? 3/4, 1 ton? how much should I expect for a junk yard special? $50 to much?
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 03-07-2005, 12:56 PM   #23
1974gmc
In Progress
1974gmc's Avatar
i think any year from early 70's to late 80's should work. i got the sway bar off a late 80's 3/4 silverado, and the frame brackets off a 70-72 1/2. i only paid $40 canadian for my bar so 50 is a bit much
Old 03-07-2005, 04:42 PM   #24
79gmcc15
79gmcc15's Avatar
so a bar from a 1 ton would fit on a 1/2 ton? cause that would probly be the best.
RIP ELJAY
Old 03-07-2005, 06:08 PM   #25
Slonaker
Slonaker's Avatar
Yes, and it would be thicker. I paid about $20 for my bar with the four pieces that hold the bushings. I was unable to find any trucks with bolt-on frame brackets (they go between the bushing and the frame, riveted in on trucks factory eqipped with swaybars), so I bought them from the dealer.
Slonaker
Stock '01 Silverado
