Old 02-28-2005, 10:37 PM   #1
69 Short Fleet
Outlaw II 15x10 Clearance ?
Does anyone know if I'll have clearance problems with Outlaw II, 15" X 10" with 4" backspacing on my 69 c/10 leafspring stock rear end, stock suspension? I'm concerned about them clearing the inside or back of the inner fender, thanks Doug
69 Short Fleet is offline   Reply With Quote
Old 02-28-2005, 11:05 PM   #2
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I don't know what the spacing is on these,I can measure it tomorrow if needed.They do fit fine though.They may only be 8's,didn't measure them.31x10.50s mounted on them.
Tha back are wider than the fronts though
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 02-28-2005, 11:11 PM   #3
1971ChevyTruck
1971ChevyTruck's Avatar
I'm pretty sure they will fit...
1971ChevyTruck is offline   Reply With Quote
Old 02-28-2005, 11:46 PM   #4
69 Short Fleet
I'd like to run a 50 series tire on them (rear) from what I checked on ARE's website all the 15 X 10" Outlaw I (the 15" X 10" 6 bolt Outlaw II is discontinued) have 4" BS in a 6 bolt aplication, I'm not into big fat slicks or a prostreet style tire but just a 50 series with a nice profile. I'm not sure if a 60's size would fit on a 10". My biggest concern is the sidewall rubbing on the inside against the inner fender.
Old 02-28-2005, 11:50 PM   #5
Brainchild
Brainchild's Avatar
These wheels had 275 60x15 ,on them when I took them off the other truck,not low profiles.I don't think you'll have a problem with clearance.
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
