Old 03-01-2005, 10:50 AM   #1
Crazy-J
Crazy-J's Avatar
Will a 16x8" wheel with 4.5" backspacing work on a 72?
Hi all,
New to the board and have a quick question.
I have a 1972 shortbed that I recently bought. I want to change out the wheels on it and I recently found a set that I like. They are 16x8 with a 4.5" backspacing. Would this work on an otherwise stock truck? The truck is not lowered but is running a set of aftermarket wheels now that I don't like. I think they are 15x8 with a 255 tire in front and a 15x9.5 in the rear with a 275 tire if that matters at all.
So just looking to see if the 16x8's with a 4.5" backspacing will work on all 4 corners and does that look fine on a '72? My only other option would be to go with a 16x9.5" with a 5.0" backspacing on the rears which might look better but not sure about that backspacing.
Thanks for any and all help!
Crazy-J is offline   Reply With Quote
Old 03-01-2005, 06:22 PM   #2
Crazy-J
Crazy-J's Avatar
Bumping this just in case. Anyone know if the 4.5" backspace will work? I'd like to order up the wheels soon. They are Centerline Meteor's by the way
Old 03-01-2005, 07:19 PM   #3
farside847
farside847's Avatar
I seem to remember a stock 72 will rub in front with a 4.5" backspace. I have a 71
and was told to go with a 3.75" to 4" max backspace. You should be able to find
16x8 with that kind of backspace though.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 03-01-2005, 08:08 PM   #4
71Rat
ran out of money
71Rat's Avatar
i have 15x8's all around and i beleave my backspacing is 4.25..... i know i have a set of 15x10's on the rear with 5 bs and they dont rub
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 03-01-2005, 09:55 PM   #5
Crazy-J
Crazy-J's Avatar
Thanks for the info. I am thinking of eventually going with 2.5" drop spindles in the front, would that affect the backspacing I would need?
Old 03-03-2005, 09:46 AM   #6
71Rat
ran out of money
71Rat's Avatar
it could limit how tall of a tire you run in the front, for me i have a 2.5 drop in the front and 4 in the rear.... nothing rubs, i think my front tire is a 255/60/15
hope this helps
Rat
