03-01-2005, 12:18 PM | #1 |
grounding question
what size grounding straps do i need for my 67? where do they go? where can i get them? if it is something i can just buy at a parts store i will go get them today. any pics would be greatly appreciated because i have so many freakin ground issues it aint funny.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
03-01-2005, 12:59 PM | #2 |
GMC Pauls has a kit to replace the original straps. He probably can tell you the original locations.
Keith 70 CST longbed in progress. Hoping to get it back on the road soon. |
03-01-2005, 01:21 PM | #3 |
Still drivin' a Rat Rod
A short battery cable will work also,from the back of the engine to the frame.Get a cable that has an eyelet in each end.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
03-01-2005, 01:24 PM | #4 |
i need to know where the cab get's grounded at? i can be creative with the motor...the cab is what im worried about....my dash panel is all goofy my glove box light flickers....when i turn my parking lights on they work when i go to headlights the parking lights go out stuff like that...
03-01-2005, 01:53 PM | #5 |
all you people that have restored trucks and you cant tell me where they go and how long i need?
03-01-2005, 02:29 PM | #6 |
doesnt really matter where they go, just go from the cab to frame, bed to frame, and motor to cab, make sure its clean metal you wire to.
03-01-2005, 02:39 PM | #7 |
where can you get them at? i went to advance and all they have is a little wimpy one...how long do i need....
03-01-2005, 11:06 PM | #8 |
its all about the +6 inches
the stock ones from the frame to cab and frame to bed and the engine to cab were "wimpy". You could use 12 guage wire with crimp on terminals on either end.
As for your dash lights, if you were to make a ground strap or or go buy a wimpy one, and ground the inst panel to a bold under the dash, I'd bet it'll work. And as for the glove box light...remove the light assembly, and wrap some sand paper around your finger, get your sand paper covered finger into the hole and just twist it back and forth a couple times. I'd bet a punch in the gut that these two things would fix your problems. |
03-01-2005, 11:32 PM | #9 |
I say this becouse you make no mention of other things not workin properly....cab light, wipers, heater, stereo...so that means all of those (or what ever you may have out of that list) all have good grounds.
03-02-2005, 09:09 AM | #10 |
Watch out for your cornhole !
The factory ground strap goes from frame to cab at the right front cab mount area.
03-02-2005, 02:50 PM | #11 |
These Are The Ground Staps That I Use On Every Vehical I Build Or Own. They Are Braided Steel, Are 15" Long, 1" Wide & About1/16" Thick. I Get Them At Summit For $4 Or $5 Each. I Think They Are Pt.# Is 148014. They Are About 20 Times Heavier Duty Than The Wimpy Stock Ones. John
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
03-03-2005, 12:23 AM | #12 |
for some reason i didnt recieve e-mail notifications till now....no cab lights....the heater motor doesnt blow hardly at all and never tried the wipers....there is NO ground on the cab....except maybe what the mounting bolts do for it......here is what i bought.....im not sure if hovis is anywhere but around here or not but hovis has this length one longer and one shorter....
03-03-2005, 02:24 AM | #13 |
There are three grounding strap locations that I've seen:
1) Between the front right cab support and the part of the frame where the front right cab mount sits. 2) Between the right inner fender and the chassis, way up at the front of the chassis, right behind the radiator. 3) From the firewall to the engine block, barely to the driver side of the distributor. There's also a little grounding clip that is part of the dash wiring harness that is supposed to slide onto a strip of metal that is part of the dash, located behind the instrument panel, down low. Just as a side note, one problem I've seen that caused strange lighting problems was a worn out turn signal switch. The bumps on the little brass pieces that slide back and forth when you move the turn signal lever were all worn off, so the brass pieces were shorting all of the circuits together, causing major lighting problems. |
03-03-2005, 02:27 AM | #14 |
Oh, yeah, one other thing. Be sure to use a star washer between the grounding strap and the body panel it is attaching to. The star washer will bite through the paint and make electrical contact with the metal underneath.
