03-01-2005, 09:31 PM | #1 |
203, 205 208 whats the difference
I just got a 68 K10, it has a 4sp I want to change to auto, whats my options??? which is better etc.
any help apreciated Thanks |
03-01-2005, 10:03 PM | #2 |
user # 2756
203- full time 4wd has a chain and differential inside. Found behind 4spds and TH350s maybe TH400s?
205- part time gear driven, considered one of the best. Found behind all sorts of autos and manuals. Available in 1969? 208- part time chain driven, aluminum case, good but needs a lot of TLC. Has a tailshaft w/ slip joint. Will allow fluid to come out if rear driveshaft removed. Found behind TH700R4s for sure and others. Showed up in the 80s.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
03-01-2005, 10:25 PM | #3 |
you basically have 4 options...the TH350, TH400, 700R4(4L60E), and 4L80E. Depends on what you are gonna use it for and if you want OD or not.
The NP208 came behind the first 3. The NP241, which is similar to the NP208, came behind the last 3. The NP203 came behind the first two. The NP205 came behind the first two, and it also came behind the 4L80E in '91 one ton 4x4s. However due to the increase in popularity, adapters can be had to match just about any transfer case up to any transmission, but custom stuff is always expensive. Out of these 4 listed, I am partial to the overall strength of the NP205, but again it depends on what you want from the truck. Good luck with your choice.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 Last edited by 1969 GMC; 03-01-2005 at 10:27 PM. Reason: oops |
03-01-2005, 10:44 PM | #4 | |
03-01-2005, 11:25 PM | #5 |
It depends if you have lockouts on the front end or not. If you want to use a 203, you need to be sure it has been converted to use lockouts. I along with the others prefer the 205, but also like the 208's as well. I think they are easier to work with because they are lighter.
When she starts to knock, bury the pedal and give it a proper death. |
03-01-2005, 11:45 PM | #6 |
Thanks guys, I'll look for a 205 and tranny
03-02-2005, 12:11 AM | #7 |
huh ???
The 208 also came behind sm465 4 spd...
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
03-02-2005, 01:23 AM | #8 |
SM465 was available with all transfer cases 203, 205, 208, and 241
03-02-2005, 01:25 AM | #9 | |
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
03-02-2005, 01:29 AM | #10 |
just passing along information... god knows you can never have too much of that. i am sorry that i disgraced your forum oh mighty 4x4 god.
