Old 03-02-2005, 01:17 PM   #1
79Silv4x4
Workaholic
79Silv4x4's Avatar
Correcting electronic speedo???
I just put new tires on my '91 Burb (about 3 inches taller). Is there anyway to calibrate/correct the speed sensor since it is the electronic one? I have seen fixes for later model year vehicles but can't seem to find anything for this year.
Rob
79Silv4x4 is offline   Reply With Quote
Old 03-12-2005, 08:26 PM   #2
TrainD5115
North Coast, baby!
TrainD5115's Avatar
Don't they make a programmer for that? I thought I just read something on this that you hook up to the ECM to recalibrate for larger (or smaller) diameter tires.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 03-12-2005, 10:56 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
All you need to do is change is the gears. You can find a calculator and gears at www.tciauto.com. Look under their technical section then speedo gears.
Read this page. http://www.geocities.com/crosley_az/700spd.htm
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-13-2005, 12:16 AM   #4
79Silv4x4
Workaholic
79Silv4x4's Avatar
Thanks G but, correct me if I am wrong, this applies to taking a tranny that has electronic speedo provisions and converting it to cable drive to mate to a cable driven speedo? ASs I understand it, my speedo is electronic and has no provisions for a cable so converting the tranny to cable drive would not help. . . However, as best IU can tell, I need to modify (or have modified) the DRAC in order to adjust for changes in gear or tire diameter.
Train--it works that way for the majority of vehicles but not for this one. I used a Hypertech programmer to adjust the speedo in my '96 & 97--easy as can be with those. . . too bad I can't do that here. . .
Old 03-28-2005, 09:59 PM   #5
Do you have a 4L80E?This application(`91 Sub)seems passed-over by the aftermarket.I put 35s on mine and called Jet,Superlift,and anyone else I thought would make a VSS-Buffer.No luck,mine`s a 6.2 diesel and the trans uses a stand-alone computer.I gave up.My next move was to try to see what street rodders use when running a 4L80E.I know mine`s 10%off.I have 4.10s and if I went to 4.56s with the 35s,I`d have 4.09s.But,power`s good,so I`m leaving it alone.
Old 03-29-2005, 03:27 AM   #6
u2slow
Web Wheeler
u2slow's Avatar
Read up on the DRAC module.
http://614streets.com/drac.html
'66 C10 longstep - Clifford equiped
'84 C20 Suburban 6.2L - awaiting 4x4 conversion
'91 V3500 Crewcab - awaiting diesel swap
u2slow is offline   Reply With Quote
