Old 03-02-2005, 02:48 PM   #1
72skytop
72skytop's Avatar
Lights flickering....Can I say "flickering"?
Ah well...anyway. My 1971 truck's lights get kind of dim at idle and flicker like crazy. I have replaced the voltage regulator on it in the past but this is something that has since started. I have heard stories of ground problems and the like...Any simple things to check without replacing the obvious...alternator, voltage regulator...etc... Thanks
Kevin Korff
Evansville, IN 47711
1997 Silverado 3500 LWB Vortec 454, headers 4.11 posi. Victory Red WOW!
1976 Oldsmobile 98 Regency four door 42,000 miles original paint. This is still a car!
1990 Oldsmobile 98 Touring Sedan 34,000 miles
1983 Hurst/Olds 30,000 actual miles
2013 Ford Taurus SHO
1972 Hurst/Olds-a work with no progress
1972 Oldsmobile 442 Convertible 455
72skytop is offline   Reply With Quote
Old 03-02-2005, 03:07 PM   #2
longhorn71
longhorn71's Avatar
check all the grounds.it sounds like a poor ground to me.
longhorn71 is offline   Reply With Quote
Old 03-02-2005, 03:48 PM   #3
HuggerCST
HuggerCST's Avatar
Mine did that the other day after I removed the B&M floor shifter & hooked up the stock column shifter. I added a ground wire from the engine to the cab & fixed it. For a quick test, hook some jumper cables between the two (on bare metal areas like the master cylinder, etc) & see if it goes away.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
