Old 03-02-2005, 04:06 PM   #1
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Question for others with 1 piece driveshaft in lwb
I have recently upgraded my lwb to a one piece driveshaft. They removed the bracket that was holding the carrier bearing and ran the driveshaft through the original hole in the crossmember.
My question is this.
If I lift my truck up by the frame, like when I get my tires changed, will the driveshaft hit the bottom of the crossmember's hole?
And if I load my truck down with.... stuff.... will it then rub on the top of the hole?
Just something I didn't even think about until after it was done and I was looking at it.
Todd
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 03-02-2005, 06:13 PM   #2
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
My son has a 1 piece in his 71 LWB and has No Problems
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 03-02-2005, 07:26 PM   #3
toddtheodd
toddtheodd's Avatar
Good. I'd hate to have the driveshaft hit the crossmember when lifting the truck. It would not be cool to bend the driveshaft after I just got it.
IIOY???
Old 03-02-2005, 08:59 PM   #4
71sub
71sub's Avatar
I've been running mine for 3+ years w/o any problems ....
71 C/10 : 350 / 700r4 ; Ford 9" posi 3.50 with 31x10.5 rear tires, single drive shaft, C-notch, 2.5" drop spindles, keyless entry
71 Suburban 350/350 -- caddy tail lights, keyless entry, late model seats, billet Autometer instrument cluster
70 Ford Torino -- 351W (balanced & blueprinted ), C4, VDO gauges
71sub is offline   Reply With Quote
Old 03-02-2005, 10:04 PM   #5
1970 CST Short Wide
Senior Moment
That doesn't you shouldn't look before you lift it, better safe than sorry
Pittsburg Ca
94565
Old 03-03-2005, 01:35 AM   #6
muddpile
muddpile's Avatar
I have a LWB 72 with the one piece driveshaft and was planning on doing a leaf flip on the back to take it down 5". I'll have to check for rubbing also.
muddpile is offline   Reply With Quote
