Old 03-02-2005, 05:16 PM   #1
byrd
Union Electrician
byrd's Avatar
How To Know If #s Match?
I'M SURE THIS HAS BEEN DISCUSSED,AND I WASN'T ABLE TO FIND IT. I WOULD LIKE TO KNOW WHERE TO GO FIND OUT AND WHAT ALL IS NEEDED? THANKS RANDY
byrd is offline   Reply With Quote
Old 03-02-2005, 05:35 PM   #2
redz 1970 K5
OBS guy
redz 1970 K5's Avatar
Truck's Partial VIN # is stamped on the engine's pass side head in the very front by the valve cover, along with factory info.
That partial VIN should match the VIN of the truck on the VIN plate in the driver's side door jam.
There is also a partial VIN stamped on the frame, and I am sure on the transmission too- someone else can help with the location of those.
88 Suburban
Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear,
Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more
redz 1970 K5 is offline   Reply With Quote
Old 03-02-2005, 05:58 PM   #3
Dual quad
Smell that burnin' rubber
Dual quad's Avatar
What redz said and ...
Generally, the part & casting numbers for the individual components (intake manifold, exhaust manifolds, block, etc) should match the vehicle application and should be date coded within a 3 month window prior to the vehicle's build date.
Dual quad is offline   Reply With Quote
Old 03-02-2005, 06:15 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Originally Posted by redz 1970 K5
There is also a partial VIN stamped on the frame, someone else can help with the location
USUALLY NEAR THE STEERING BOX ON THE FRAMERAIL
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-02-2005, 06:31 PM   #5
Rod
You can identify starters and tranny's and alternators and a whole lot of other stuff also to verify correct numbers matching application. It can get into some fine details if you try to go all the way.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 03-03-2005, 12:51 AM   #6
roger0080
If you have the Protect-O-Plate for the truck you should be able to check the following matches:
o VIN (of course)
o Carburetor Source Code (possibly)
o Engine Number
o Rear Axle Number
o Vehicle Build Month Code
o Transmission Number
-Roger
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
