Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 06-02-2002, 10:54 AM   #1
Fast68Chevy
Fast68Chevy's Avatar
parting 78 silverado
body is total scrap, more than you can believe even more than im used to seeing and thats saying something..
its a 78 silverado had 350 and th350 i have found out today, some of th eparts that are good on it are as follows, i will keep adding more as i find out more:
V-8 tachometer instr cluster, taking offers, has small fuel gauge on left side
power locks equipment
all good headliner trim pieces ,
driver side front pillar trim panel is good,
pass side rear pillar trim panel is good
deluxe metal yellow grille bowtie(10)
hood(25)
steering column with tilt, but is loose, needs tightened, maybe se for parts ?
very good nice shape later model steering wheel, 79-up style with the later smaller stainless steel colored insert horn cap, sell cheap
spare tire carrier bracketry, all is there including spare tire still(25)
large deluxe hood ornament(15)
hood hinges pair(20)
silverado bright grille trim pieces and bright grille filler panel parking lamps (12)
wiper motor(15)
bumper brackets(15)
misc A/C parts no compressor or brackets just cab stuff
silverado fender badges, need repaint(10)
nice outside cab corner aluminum bowtie wraparound bright aluminum band pieces for just under back glass level(15)
good brake power booster(25)
engine/frame mount trees/brackets/towers(20)
p/s gearbox(25),
driveshaft(25) that will work in 67-72 trucks also,
auto trans crossmember(15),
12 bolt rear and all leaf and hangers shackles etc- spring pad spacing is 42.5" just like in prior years, fuel tank (25)
good disc brake entire front assembly would be good for pre'70 brake conversion(50), the bench seat is halfway decent is light beige cloth(20), would be good for work truck, etc,
lots more, parting all, package deals can be made with other parts off other vehicles too
Fast68Chevy is offline   Reply With Quote
