Old 03-03-2005, 04:10 PM   #1
brat88
Angry starting problemms
undefined my 88 burban just stop, 350 TBI was runnig good,but would die when I slow down to make a turn ,then it got to where it takes long to start, also it would not respond when I press on the gas ,now it will not start at all , I think my fuel pump is bad, and I know that my sending unit is bad cause the gas gauge has not worked for somtime, service engene light has not come on
please help
thank you
Ralph
brat88 is offline   Reply With Quote
Old 03-04-2005, 12:09 AM   #2
72k5
72k5's Avatar
Welcome to the board!
I think they moved your post because it's an engine and drivetrain kind of question.
Well, the throttle position sensor could be bad, but so could just about any other component on the vehicle. For that matter, it could be a big vacuum leak.
Start with making sure the ignition is good - replace anything that looks bad, or is over it's replacement schedule. I think 30k for plugs, and 60k for cap, rotor, wires is a good conservative rule of thumb. Have you changed the fuel filter as needed? A new one would be a good investment at this point.
If you're going to change the sending unit anyway, now would be a good time, if it is a modular unit that includes the fuel pump.
I also think that it is never a bad idea to have a spare ignition module in the glove box, so you might try one. It probably won't fix it, but you'll have your spare. And if it should happen to help, it's 20 or so bucks very well spent.
If this fixes your problem great, if not, you've done the preventative maint. that you were going to have to do anyway, and you can get on with diagnosing the problem with the knowledge of what isn't causing it.
I know this sounds a lot like just parts changing, but it's not, if you limit it to the kinds of things that need regular replacement, and are due. I can think of a number of tests that might shed some light on things, but the lack of any tests on your part so far, and the fact that this has been getting worse for some time, makes me think your tools are limited. So, make sure the basics are covered, then you'll have to decide if you are going to invest in stuff like a fuel pressure gauge, manuals, etc., or take it to a pro.
350 ETec 170 heads, Performer, HEI, Holly TBI, 700r4, 14 bolt rear, F&R lockers, lots of off road improvements.
72k5 is offline   Reply With Quote
Old 03-06-2005, 01:18 PM   #3
brat88
72k5, thank you I have new plugs, fuel filter and wiers.wereis ,where is the throttle position sensor located.I changed the fuel pump relay and got it stated, but the idel is suerging up & down when i give it gas it hesitate .
thank you
ralph
Old 03-06-2005, 08:40 PM   #4
bisquik65
bisquik65's Avatar
You may want to change your distributor,pull it out,if it turns tight,replace it. This tightness slows down the injector driver and thus makes a stalling cond. I have seen that alot with the new style dist,But check the coil too(cheaper) common for those to break down,look for white chalk like on the sides of the coil. Just my opinon,Erick Wrenching since 1982
bisquik65 is offline   Reply With Quote
