Old 03-03-2005, 04:35 PM   #1
stick
Question on th 350 tranny
I'm a new member and have a friend that just bought a th 350 tranny with a lockup converter out of an '80 Chevrolet half-ton. He has put it in a '55 Nomad with a new small block GM crate engine. Two questions. I'm assuming, in calculating which speedo gear he needs, that the th 350 has an 8 tooth drive (not driven) gear. I think the truck was a two wheel drive. Is that correct?
Also, there is a single green wire coming out of the transmission which we are assuming is the on/off for the converter but we don't have a clue as to how to run the wire. Any ideas on that?
stick is offline   Reply With Quote
Old 03-03-2005, 05:02 PM   #2
1FaastC10
1FaastC10's Avatar
need more information on the car to accurately say what speedo gears you need. rear axle ratio, tire size, and specifically what the speedo gears are in the trans now would be helpful. the drive gears are not a constant tooth count, they vary with tire size and rear axle ratio.
1FaastC10 is offline   Reply With Quote
Old 03-03-2005, 05:26 PM   #3
1974gmc
In Progress
1974gmc's Avatar
here is a kit my b&m search on summit racing part # BMM-70248
1993 Chevrolet K2500 454 4L80E
1974 GMC 1/2t 2wd Stepside 305 auto *sold*
1985 Ford Mustang GT 5.0 5spd
1974gmc is offline   Reply With Quote
Old 03-03-2005, 05:26 PM   #4
stick
Sorry I wasn't clear. I've got the formula to determine the speedo gear, I was just wondering if anyone knew what drive gear originally came in the transmission. He is running a 3.55 with 27 1/4" wheels and so I calculate a 21 tooth speedo gear with an 8 tooth drive gear.
Old 03-03-2005, 05:41 PM   #5
stick
Thanks for the tip on the lockup kit. That's a cool option which I will show him. We were hoping that we would be able to wire it into the Nomad's system but he may just end up running without it. Guess we could just use a toggle switch but that's not a good solution either.
