Old 03-03-2005, 04:47 PM   #1
67chops
67chops's Avatar
Gear Indicator
Im sure this has already been answered but the search tool is down for now so i will ask again. where does the fiber optic cable that goes to the shift indicator plug into? thanks
-Chops-
67chops is offline   Reply With Quote
Old 03-03-2005, 04:50 PM   #2
jhow66
jhow66's Avatar
To a "white" bulb holder next to speedometer.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-03-2005, 05:28 PM   #3
67chops
67chops's Avatar
Thanks alot, the wiring under my dash is quite a mess from the PO and im trying to get some stuff fixed.
-Chops-
Old 03-04-2005, 12:53 AM   #4
67chops
67chops's Avatar
i looked under my dash and next to the speedometer for a "white" bulb holder. i snapped a picture if you could point out what im looking for that would be great. thanks.
-Chops-
Old 03-04-2005, 01:29 AM   #5
jhow66
jhow66's Avatar
Seems as yours does not have it. I will snap you a picture of it tomorrow.
Old 03-04-2005, 01:40 AM   #6
67shortie
Green club
67shortie's Avatar
Cool, something I did not know. I converted my manual trans to a TH350 and did not know where to put the fiber optic light went.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 03-04-2005, 08:24 AM   #7
byrd
Union Electrician
byrd's Avatar
I have one of the fiber optic bulb holders if you need it. I want $2.50 plus shipping. here is a pic of what you need. Randy
byrd is offline   Reply With Quote
Old 03-04-2005, 11:12 AM   #8
jhow66
jhow66's Avatar
That's what you need.
Old 03-04-2005, 12:13 PM   #9
67chops
67chops's Avatar
now how would i swap that white bulb holder onto the circuitboard? also, because i do not have it does that mean my truck was originally automatic? i may be taking one byrd. ill send you a pm later.
-Chops-
Old 03-04-2005, 12:23 PM   #10
smokekiki
Mike
smokekiki's Avatar
If it was an automatic it would have had one.But they go missing after years of changing hands.Do You have the fiberoptic cable?The cable slides thru the tab on the bulb holder.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 03-04-2005, 12:25 PM   #11
smokekiki
Mike
smokekiki's Avatar
The pics are of the backside.They go on like the other ones.Yhe cable just picks up the light from the bulb.
Old 03-04-2005, 12:44 PM   #12
byrd
Union Electrician
byrd's Avatar
I'll look for the pm later. as for the install of the fiber to the bulb holder. there is a little retainer clip that holds the fiber to the bulb socket. you will have to slip the fiber end into the hole in the bracket on the bulb holder and push the little clip on the bracket to tighten up on the fiber end and hold it. this is the same as the other bulb holders and will just twist in and out just like the one you will need to remove to install this one after you put the fiber and and bulb socket together. hope this clears it up . Randy
Old 03-04-2005, 12:51 PM   #13
67chops
67chops's Avatar
i do have the cable but the end that attaches to the dash was cut. i am going to try to find a similar metal piece that goes on the end so that i can repair this because it looks like the wire is hard to find. byrd once i find out for sure if i can repair my fiberoptic cable ill send you a pm, that may not be till early next week seeing as i have to work all weekend and wontt get a chance to touch my truck.
-Chops-
