Old 03-03-2005, 05:10 PM   #1
aitch
aitch's Avatar
2 1/2 + 1 = 3 1/2?
I'm getting set to drop my 3/4 69 GMC LWB, changing to 1/2 ton 5 lug suspension.
I have 4 inch drop coils for the back and 2 1/2 drop spindles for the front.
Should I add 1" drop coils in front and would that combination give me a total of 3 1/2? I want to level it out.
Anyone have pictures of this stace?
Thanks,
Aitch
aitch is offline   Reply With Quote
Old 03-03-2005, 05:51 PM   #2
69 longhorn
in theory, that will give you 3 1/2" drop, but in real life, your front springs may have a little sag in them. these trucks stand a little higher @ the rear, so if you like a level stance, i would try the 4" rear, & just swap the spindles up front.......I think you will be pretty close. one thing on the springs tho....if you want 1" more drop, you may look at a 1 1/2, or 2" drop spring, as the factory pcs are bound to have a little sag. best of luck,69L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-03-2005, 06:20 PM   #3
aitch
aitch's Avatar
69L, I suspected that the numbers did not necessarily add up. That's good information. I'll probably hold off on the front drop coils until I get a look at the stance with the 2 1/2 - 4 drop.
Thanks, aitch
