Old 06-02-2002, 01:48 PM   #1
Low69CST
Door courtesy light switches
What years are these supposed to be on and were they standard or options? LMC says they were available 70-72 however we have a 72 cab that doesn't have the switches in it. So were just available on Cheyenne Super's and CST's from 70-72 or where they available on all CST's and Cheynenne Supers from 67-72?
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-02-2002, 01:55 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Never standard, I think optional from 69 and up...maybe 68.
Pain in the rear withoput I think. 2 of my 3 have/had the switches.
Old 06-02-2002, 02:01 PM   #3
Low69CST
oh yeah, should they be on both doors or just drivers?
Old 06-02-2002, 02:05 PM   #4
Longhorn Man
Both.
The switches are available in most of the catalogs, and the harness is a piggy back one that may be repoduced, and if not, easily taken from another truck in a wrecking yard.
Old 06-02-2002, 02:40 PM   #5
70c10
67-72 Addict!
70c10's Avatar
Question
Where do you connect the wires to?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-02-2002, 04:12 PM   #6
Benrs86
Benrs86's Avatar
the dome light wireing harness is white and orange. under your dash the white and orange wires have a plug in and just unplug that plug, put a orange wire to go from orange on one plug to orange on the other, and white wire should come out one plug, split to each switch, and to the other plug, you should just go pick up the little harness from a junkyard and it is easy to figure out, by the way, if you are drilling holes for the switches, you need a pipe thread tap. number 8 pipe? no, i dont know, good luck, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 06-02-2002, 07:22 PM   #7
Fast68Chevy
Fast68Chevy's Avatar
this option was not available in 68 yet
Fast68Chevy is offline   Reply With Quote
Old 06-02-2002, 08:55 PM   #8
Longhorn Man
Thanks Randy...I wasn't sure.
