Old 03-03-2005, 08:40 PM   #1
pedrofixlater
75 STEPSIDE
pedrofixlater's Avatar
Question Newbie here
Just want to say hello to all. I am doing a frame up resto on a 75 stepper. I have aquired an 86 cab rust free. So far just getting down to the frame should be ready in APR. Any hints on the wiring, my 86 cab had steering column with blinker controling wipers and hi beam low beam, my 75 cab was seperate. I have the 75 steering column and seperate hi/low beam switch and wiper switch.
pedrofixlater is offline   Reply With Quote
Old 03-03-2005, 08:51 PM   #2
Russell
Professional Grade
Russell's Avatar
I hope you took into consideration that your 73-80 era front sheet metal won't bolt onto the 81-87 cab... If you are handy with wiring you can set it up however you want
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-03-2005, 09:22 PM   #3
pedrofixlater
75 STEPSIDE
Question 86 cab on 75 stepper
what will i run into trying to put my 73-80 front quarters on 86 cab
Old 03-03-2005, 09:35 PM   #4
smokinn
smokinn's Avatar
The bolt holes wont match up and body lines.
smokinn is offline   Reply With Quote
Old 03-03-2005, 11:00 PM   #5
Bowtie4by
I've got 79 fenders on an 85 cab. Everything lined up and worked fine.
Bowtie4by is offline   Reply With Quote
