Old 03-04-2005, 12:01 AM   #1
CHEVY & GMC FOREVER
Turbo-Hydramatic 375 Transmission???
Did anybody ever hear about a Turbo-Hydramatic 375 Transmission before??? and if so do you know if it was an option for our trucks???
1985 Chevrolet C-30 454 1-TON Dooley
1969 CHEVROLET CST-10 PICK-UP
Good memories
1999 Chevrolet Z71 Ext. cab 5.7L
Good Memories
With a quart of oil, and a gallon of gas, she won't let no other car pass!!!.
& FOREVER
CHEVY & GMC FOREVER is offline   Reply With Quote
Old 03-04-2005, 12:18 AM   #2
Green Machine
Green Machine's Avatar
Isn't that just a long tail shaft turbo 350 with BOP (buick olds pontiac) bellhousing ? Turbo 400 size rear yoke ?
Green Machine is offline   Reply With Quote
Old 03-04-2005, 12:20 AM   #3
CHEVY & GMC FOREVER
I don't know, I was reading one of my car books from are years and under the section which tells you if the car can be started by pushing there was a listing of and the TH's and it clearly said TH-375.....
Good memories
Good Memories
& FOREVER
Old 03-04-2005, 12:31 AM   #4
Purs
Got Big Block?
Purs's Avatar
375's got the internals of a TH400 (mostly) but the output shaft of a TH350. I think they came in vans and taxis, maybe a few buses too. good stout tranny's.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 03-04-2005, 12:47 AM   #5
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I've heard of it,I understood it to be a longshaft 350 also.
I found this,intresting reading
THM375B - This trans is identical to the THM350, but is considered a heavier duty transmission.
THM375 - This transmission is a derivative of the THM400 sharing the external appearance of the 400. It'll be marked 375-THM on the bottom of the tailshaft housing. It's a light duty version of the THM400, has ABSOLUTELY NO RELATION to the THM375B, and was found in 1972 to 1976 full-size cars. The Turbo 375 was modified to accept the Turbo 350 driveshaft yoke.
http://www.nastyz28.com/transid.html
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
